Pre-Amp or Integrated Amp
Irrenhaus
Irrenhaus Posts: 1,105
edited March 2013 in Electronics
Okay so here is the thing
Thinking about getting a Tube Integrated Amp options for now a Yaqin MC-10T or MC-13S but I can also get a Tupe Pre-Amp and use it with a Parasound 2125.
Either choice will be to drive my Linns for stereo only. Any advice i have not research any preamp yet and this is my firsy try at tube gear. So I guess is a new rabbit hole....:')
Cheers
HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
Post edited by Irrenhaus on
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited March 2013
    Well the yaqin sounds great but spend a little bit more and get one of the Dared tube preamps as they are said to sound great. My friends going to buy one shortly so I cannot wait till he lets me borrow it to use with my new DAC
    http://www.ebay.com/itm/New-Dared-MC-7P-full-tube-high-end-preamp-w-phono-input-remote-more-best-of-best-/360610460369?pt=US_Home_Audio_Amplifiers_Preamps&hash=item53f60ef2d1
    Go with something like this then adding better amps and dac's are going to change the experience. With tube integrated systems your limited for choice and they have less than stellar resale value if you should decide to rid yourself of it later down the road. Get that tube pre and take itto the next level and get into rollin in tubes etc...
  • Irrenhaus
    edited March 2013
    Nice was looking at the Jolida JD5T but like the Dared it has a phono stage nice.
  • polkfarmboy
    edited March 2013
    And the Dared is a fine looking pre with all the tubes exposed for eye candy, I don't think youl find another new that competes. But you can find one of these consonance 222's used for the price of the new Dared if you keep a look out
    http://www.opera-consonance.com/products/cyber222.htm
  • Irrenhaus
    edited March 2013
    Well looking at more options. Found a Audionote M1 in mint condition going for $700.00 and a Audio Research SP9 MKII for $750.00 also in mint condition. Will have to audition.
    Cheers
  • capricious
    capricious Posts: 3
    edited March 2013
    I've a yaqin integrated (hybrid) - tube pre and SS amp. It is the best sounding amp in my house. I have a denon 2809 and a yamaha 3000. So my experience with a hybrid solution has been very good so far. Pair your parasound with a good tube pre, and you are going to be very happy. Look at odyssey candela (~$800 used) as well along with yaqin.
  • wstrickland1
    wstrickland1 Posts: 11
    edited March 2013
    tough question
  • Irrenhaus
    edited March 2013
    capricious wrote: »
    Thanks for the info. Last week i scored a B&K Avp 3090 for 15 bucks i am trying that one for now in stereo and is not bad. But i am still looking for a nice preamp hybrid or or tube did not got a chance to listen to the AR yet.
    Cheers
