What am I missing?
valkyrie00
Here's my set up. Just wanting to get everyone's opinion on what I should add to improve my hardware in its current state. Bearing in mind this question pertains to home theater AUDIO only:
Polk Audio RtiA9 - Front x 2
Polk Audio CsiA6 - Center
Polk Audio FXiA6 - Surrounds x 4
Denon AVR 3313 CI
Oppo BDP 103
Emotiva XPA-5
SVS PB12 NSD
I was thinking of adding another SVS sub and/or another amp to drive the fronts only >200 WPC. My Emotiva currently powers the fronts, center, and sides. The receiver powers the rears... Any thoughts would be greatly appreciated. Any comments directed toward audio only please.
Denon AVR 3313 CI
Oppo BDP 103
Emotiva XPA-5
SVS PB12 NSD
Denon AVR 3313 CI
Oppo BDP 103
Emotiva XPA-5
SVS PB12 NSD
Denon AVR 3313 CI
Oppo BDP 103
Emotiva XPA-5
SVS PB12 NSD
Post edited by valkyrie00 on
I would have probably went with an RTI A1 or A3 for the rears instead of the FXI A6 myself. Other than that, it sounds like a great set-up. What issue are you having, if any.
A 2nd SVS PB12 NSD might be my choice. Dual subs can make quite a difference depending on your room size.
What do YOU think is missing or lacking?
What is it you seek?
And - how much is your budget?
No issues. I was just wondering if there is something everyone might add to a similar setup. I agree with the second sub based off what I've read in this forum. My room size is 14'x23'.Polk Audio RtiA9 - Front x 2
Denon AVR 3313 CI
Oppo BDP 103
Emotiva XPA-5
SVS PB12 NSD -
valkyrie00 wrote: »No issues. I was just wondering if there is something everyone might add to a similar setup. I agree with the second sub based off what I've read in this forum. My room size is 14'x23'.
Nice rig.
Stop obsessing and enjoy some music! :cheesygrin:
Another sub would surely increase your bass response. The addition of an XPA-2 to drive your mains would make your 2ch listening improve IMO. Aside from that, like DSkip mentioned, you have a very solid system.
I would agree Geoff, the 9's will put to GOOD use all the power you can throw at them, to quote Geoff, "MO POWER"Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
As recommended, I have been kicking around the idea of driving the fronts through an XPA-2. However, and this may seem like an idiot question from an idiot newb, but will the extra 100 watts make that much of a difference? My listening is 90/10, Movie/Music.Polk Audio RtiA9 - Front x 2
Denon AVR 3313 CI
Oppo BDP 103
Emotiva XPA-5
SVS PB12 NSD -
Drove mine with the XPA-5, until I got the XPA-2 and there was a very noticeable difference with the -2Home Theater
Two Channel
Have you looked into room treatments, or upgrading your speaker cables/power cables?
+1, drove mine with an XPA-3, equivalent to the XPA-5 in power, and was VERY happy with the X-tra 100w.
And, BRun has an awesome suggestion with Rm Trmts -
What B said.
What are your room dimensions ?Speakers: SDA-1C (most all the goodies)
Thanks to all for the suggestions. All of my cabling is Audioquest and I use 12 gauge speaker wire all the way around. I know this may seem like overkill considering my room dimensions of 14'x23' so place that one in the "newb mistake" category. Can anyone recommend a good place for acoustic paneling and some idea as far as placement? I understand the whole "reflection point" placement idea, but is there anything else I'm missing?Polk Audio RtiA9 - Front x 2
Denon AVR 3313 CI
Oppo BDP 103
Emotiva XPA-5
SVS PB12 NSD -
DSkip, thanks for the advice. I will check it out...Polk Audio RtiA9 - Front x 2
Denon AVR 3313 CI
Oppo BDP 103
Emotiva XPA-5
SVS PB12 NSD -
Add second matching sub...sit back & enjoy! Nice system you have there...even better when you add another matching sub. "nuff said.
I vote for another SVS PB12 NSD.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
Also agree on adding a second sub, or look into using REW software from home theater shack and work on eq'ing the one you have. Either way room treatments or another sub will be a huge upgrade, didn't know you had Audioquest wire you should be good to go in that department.
My response eludes to your post title. What are you missing?? Sounds like a pretty stellar rig to me. If you are feeling the lack of bass than obviously a 2nd sub "could" be your answer. Otherwise cables, IC's, room treatments, etc might be a better use of funds. JMO....
Thanks again for all the tips. Based on the consensus here I believe I will look at adding another SVS sub. Awhile back someone here recommended another sub based on my room size and most of you have supported that recommendation. On another note, I am a performance car lover and it is amazing the similarities between home audio and aftermarket car parts - you can spend all you like and there will inevitably be something else you want....
I can't tell you how much help I have gleaned from this board and I truly appreciate everyone's thoughts and recommendations. I am considering a projector very soon - here we go again :biggrin:Polk Audio RtiA9 - Front x 2
Denon AVR 3313 CI
Oppo BDP 103
Emotiva XPA-5
SVS PB12 NSD
