any suggestions on tower speakers
1niteryder
I would like to get some tower style speakers for my system. Any suggestions on what to get or what not to get?
Post edited by 1niteryder on
What are you using these for, music, home theater, and what's your budget?Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
I did a martinlogan setup for my sister, I am very impressed with them.
We used the Motion 10's. They are very powerful and crystal clear ( due to that ribbon tweeter). They sounds great in both HT and 2ch audio. We were able to get them onsale at newegg for $99 each! (marked down from 600 each).
I found them at amazon for $199 each. Great deal, Great buy, awesome speaker. They aren't very big, maybe 3 feet tall.
http://www.amazon.com/MartinLogan-Motion-10-Floorstanding-Speaker/dp/B0035FZ142/ref=sr_1_1?ie=UTF8&qid=1362925183&sr=8-1&keywords=martinlogan+motion+10
If you want something bigger they next step up is a motion 12 or motion 20.
http://www.amazon.com/MartinLogan-Motion-12-Floorstanding-Speaker/dp/B0035FZ14M/ref=sr_1_1?s=electronics&ie=UTF8&qid=1362925519&sr=1-1&keywords=motion+12
http://www.amazon.com/MartinLogan-Motion-Gloss-Black-Floorstanding/dp/B007THXXXS/ref=sr_1_1?s=electronics&ie=UTF8&qid=1362925572&sr=1-1&keywords=motion+20
I did toss in a small polk sub for bass. If they had more or a budget I would have tossed in 1 or 2 B&W ASW608.
Cool thing about ML is that BestBuy has them in Magnolia, so you can go hear them yourself. They are very directional speakers so make sure they are aiming near you to get the most out of them.
Good luck, hope this helped.B&W CM9Classé Sigma -
1niteryder wrote: »I would like to get some tower style speakers for my system. Any suggestions on what to get or what not to get?
Dont know were you are located. But Frys has the RTi8 for $334.00 a pair this week.
CheersHTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV. -
Newegg has some Monitor 75T's for $219 a piece . Anxiously awaiting their arrival .
I picked up some RTi8's at Fri's for $300 the pair. They sounded great for home theater. My wife didn't like they way they looked so I sold them to my brother along with the Onkyo 609 at 100 wats per channel and a CSi center. They played louder than I could stand. I then picked up the RTIa7 with the Onkyo 809. Both speakers are fine for the price for home theater.Panasonic 65" Plasma - Panasonic Blu-ray. Onkyo TX-NR809 RTi A7s fronts - MK CS150s surronds.
JM labs Grand Utopia, Legacy Whisper HD, Wilson Sophia, PBN Montana Was or Kas.....dude.....without a budget or associated gear to drive said towers, the results here will be all over the map.HT SYSTEM-
lsi 9's -
Since you're at Polk's forum, there's always the Polk eBay store: http://stores.ebay.com/Polk-Audio-Direct?_trksid=p2047675.l2563Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
Hard to go wrong with SDA's. But not knowing budget or listening tastes....yeah, crap shoot.--Gary--
Kirsch Prodigy K803
Bad ****.
http://cdn.propertyroom.com/imageserver/sellers/seller1/images/origimgs/1_22102012154755103.jpgDo you hear that buzzing noise?
Monster Jam wrote: »Kirsch Prodigy K803
Bad ****.
Wow yeah those are Bad **** and they come with special delivery.......
I found one of these at the local GW (Digital Research PT-1100)
http://www.ebay.com/itm/Digital-Research-Speakers-/150989135459?pt=Speakers_Subwoofers&hash=item2327a75e63&nma=true&si=i4by36n2cGyJiS6QFFRGs4CqnKI%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
Obviously not affiliated
I like how they show the back and not much of the front.
The cabinets were so thin that it felt like you could pop a hole with a good whack.Stan
Main 2ch:
HT:
Other stuff:
These are for my home surround system. It is used for both music and home theater. Under $500.
thanks I will check them out.
I will go check them out tomorrow. Thanks.
