Looking for 2 channel Tube amp 75-100wpc...
KellyMic
KellyMic Posts: 166
edited March 2013 in Wanted (WTB) Classifieds
Title pretty much says it all, to power Polk LSi25's
Polk Studio Monitor 4.6 Series 2's, Polk RT1000p's, Polk LSi25's, Boston Acoustic VR-975's
Crown D-75, Crown CE1000, Crown CE2000
Post edited by KellyMic on
    EndersShadow Posts: 17,689
    edited March 2013
    Budget would be nice. Your gonna have to spend some cash to get that kinda wattage out of a tube amp.
  • nspindel
    nspindel Posts: 5,343
    edited March 2013
    You may want to investigate a tube preamp with a solid state amp - great pairing.
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited March 2013
    nspindel wrote: »
    +1 on that, a lot less denaro.and the right combo can be fantastic. ( see sig)
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    tonyb Posts: 33,068
    edited March 2013
    +2....That much wattage in a pure tube amp is some bucks. Another option is hybrid tube/ss, or even class D or ice amps. Many SS amps have a warm tube sound too. Really depends on budget.
  • charley95
    charley95 Posts: 908
    edited March 2013
    KellyMic wrote: »
    I have a Rogue Audio Cronus Magnum and love it!
    A little over $2000.00. I think it's 100wpc. rogueaudio.com
  • thsmith
    thsmith Posts: 6,082
    edited March 2013
    Probably have to go mono blocks, Manley Snapper
  • KellyMic
    KellyMic Posts: 166
    edited March 2013
    This will be my first tube and I am unsure of the power needed, speakers rated for 300w and 88 efficiency. I am currently running them on an amp that is 660wpc but the gain never goes beyond 1/3 of the way up. I need to get my multimeter out and check how many watts they are actually getting but haven't yet.
    I would like to stay around $1,000 and used is definitely an option. I'm not sure what to expect wattage wise at that price though. Total tube noob!
  • KellyMic
    KellyMic Posts: 166
    edited March 2013
    I just found a Jolida 801A 70w for $795 on Audiogon...
    I don't know anything about the Jolida amps but have seen them recommended often.
    http://app.audiogon.com/listings/tube-jolida-801a-jd801a-integrated-tube-amplifier-70-wpc-2013-02-17-amplifiers-92071-santee-ca
  • KellyMic
    KellyMic Posts: 166
    edited March 2013
    I see a Jolida hybrid that is 200w @ 4 Ohm that has a tube input stage and SS MOSFET output stage for $788. How are the hybrids amps?
    F1nut Posts: 51,700
    edited March 2013
    The general rule of thumb with tubes amps is they are equal to a SS that is 2 to 3 times the tube amp's rated power. That is, a 50 wpc tube amp will play as loudly as a 100 to 150wpc SS amp. This is because tube amps soft clip.
    There are plenty of tube amps on Audiogon. Just saw a mint VTL 50/50 with a matching pre amp (no remote control) for $850.00. Since it hasn't been used in a long time it will need to be brought up on a Variac. However, there are many others to chose from.
    That Jolida is an integrated amp in case you missed that.
  • george daniel
    george daniel Posts: 12,096
    edited March 2013
    Can't address the 25's but I had a pair of 15's with Quicksilver mono M-80's,,sweet sound,, handled the 15's pretty well. Still have the quickies,,look for a pair used.Good luck.
  • KellyMic
    KellyMic Posts: 166
    edited March 2013
    I will only be running a DAC and a TT so integrated is ok if it has a TT input, which the Jolida JD1501P does not have. From their website I see no rating for 4 Ohm so not even sure it does 4 Ohm. No manuals on their site.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited March 2013
    KellyMic wrote: »
    Those amps have 8 ohm and 4 ohm taps on the back
  • zingo
    zingo Posts: 11,258
    edited March 2013
    The LSi25s should actually be easier to drive then the LSi15s as you're not driving the woofers.
  • rromeo923
    rromeo923 Posts: 1,513
    edited March 2013
    Kelly Mic.
    I have a Yaqin ms 12b- which is a tube preamp w/phono and 1 linestage. I also have a Parasound HC -750 amp. These are a nice combo that will do everything you want and are a great way to get into tubes w/a turntable involved.
    Check out this thread. http://www.polkaudio.com/forums/showthread.php?139014-Yaqin-MS-12b-phono-and-linestage-pre-w-extra-tubes!
    PM if you want to know more. Bottom line tube pre w/phono and linestage input plus some nice nos tubes to roll, and nice SS a,mp all $450 shipped CONUS. Deal.
    I got static in my head
  • nspindel
    edited March 2013
    Also check out the Dared MC-7P. 3 line inputs plus a phono input, and the phono pre-amp sounds fantastic. Also has a remote control for volume. I have this piece and love it.
  • ViperZ
    ViperZ Posts: 2,046
    edited March 2013
    KellyMic wrote: »
    801A is a good amp, 70WPC RMS, KT88 and 6550 power tubes. I used one for a few years, it was good stock, it was VERY good modified (added choke transformer and recapped everything with Mullard and Elna capacitors).
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
