Opinions needed: Kenwood KA-60
joho1701
joho1701 Posts: 18
edited March 2013 in Electronics
Is the Kenwood KA-60 a good amp worth getting for vinyl listening with 2 KLH Model 16 speakers and the Polk PSW10
subwoofer?
Post edited by joho1701 on
  • decal
    decal Posts: 3,205
    edited March 2013
    Sure, if you ditch the POS sub.
  • joho1701
    joho1701 Posts: 18
    edited March 2013
    decal wrote: »
    Why?
  • joho1701
    joho1701 Posts: 18
    edited March 2013
    ZLTFUL wrote: »
    There are far better subs out there for only a hair more money. The PSW505 would be an example and can be had on sale pretty frequently for around $189-$199.
    Ha, I've been getting that a lot since I've been posting. However, it's my first sub and I got it for $75. Got my turntabe
    for free also (AudioTechnica LP-60) and connected everything to an Superscope PAC770 tthat I used for music study brieflyn the late 90's and was about to sell or give away. So, as you can see, as a starter kit I've been able to keep costs way way down, which is the priority right now.
    I am hoping a real amp will help enrich the sound of my vinyls, particularly the mids and highs.
    mhardy6647 Posts: 35,507
    edited March 2013
    KLH 16? I don't know that model - are these vintage KLH or later ones? If vintage, perhaps KLH 6 or 17?
    As to the KA-60, I'd consider it slightly past the "golden age" but perfectly serviceable.
    edited March 2013
    oh.
    OK
  • decal
    decal Posts: 3,205
    edited March 2013
    joho1701 wrote: »
    Why?
    ZLTFUL wrote: »
    The PSW10 doesn't have a very good reputation at all. Pretty much in sound quality, musicality and reliability.
    If you bump that budget up a hair and explore the used market, WAY better subs can be had.
    What he said. I had a psw10, it's a POS.
    edited March 2013
    And I was trying to be diplomatic.
  • joho1701
    joho1701 Posts: 18
    edited March 2013
    Now that my KA-60 is on its way how can I connect the PSW10 to it? I had a pre-out on the Superscope, but all the KA-60 has are
    phone, tuner and aux ins and one set of left and right +/- speaker inputs. (My turntable has a built in pre-amp.):
    EndersShadow Posts: 17,749
    edited March 2013
    joho1701 wrote: »
    Hookup option 2 or 3 in the manual.
  • joho1701
    joho1701 Posts: 18
    edited March 2013
    Thanks, but I'm not sure how they apply. This is a simple TT to amp to speakers set-up, not home theater. Am I supposed to run my speakers wires straight into the posts on the back of the sub sub then run wires from the sub-out posts to the speaker-in of
    the receiver? Or am I supposed to double up both speaker and sub wires to the in posts of the receiver?
    edited March 2013
    joho1701 wrote: »
    1. TT to amp
    2. Amp speaker wire to Speaker in on PSW10
    3. Speaker out on PSW10 to KLHs
    My only question is how are you controlling volume? Did you mean to say amp or Receiver?
  • joho1701
    joho1701 Posts: 18
    edited March 2013
    It's an integrated amp? It has a volume knob, bass, treble, etc as well as loudness lever.
    Here's what one looks like from the front
    http://www.ebay.com/itm/Kenwood-Stereo-Integrated-Amplifier-Model-KA-60-/261178266826?pt=US_Pro_Audio_Amplifiers&hash=item3ccf7014ca
    I'm thinking this will work fine for my turntable...
    edited March 2013
    yes, see the scan I posted earlier; it is a decidedly entry-level, compact footprint integrated amp ca. 1980 or very early 1980s.
  • joho1701
    joho1701 Posts: 18
    edited March 2013
    Thanks to everyone who replied! I'm looking forward to hearing the difference the Kenwood makes over the Superscope.
    Best regards!
