Hockey help!
dragon1952
dragon1952 Posts: 4,907
Hockey fans.....any idea what the average number of faceoff's are in a typical hockey game? This is for a contest tie-breaker answer.
Thanks in advance :)
  • gatemplin
    gatemplin Posts: 1,595
    edited June 2004
    Just a guess, maybe 45.
    Graham
  • dragon1952
    edited June 2004
    Wow! That many? :eek:
  • gatemplin
    edited June 2004
    Actually, I'm thinking it is probably more than that even though I have never counted, maybe even closer to 60 or 70. There are faceoffs at the beginning of every period, after every icing, offside, two-line pass, penalty, goal, when the puck goes into the upper netting or crowd, timeout, and when the goalie holds the puck, basically everytime play stops, which is a lot.
    Graham
  • Shizelbs
    Shizelbs Posts: 7,433
    edited June 2004
    I would be more likely to go with your second and higher guess.
  • dragon1952
    edited June 2004
    Awright! Thank you one and all. ;)
