Hockey help!
dragon1952
Hockey fans.....any idea what the average number of faceoff's are in a typical hockey game? This is for a contest tie-breaker answer.
Thanks in advance
Thanks in advance
Wow! That many? :eek:2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
Actually, I'm thinking it is probably more than that even though I have never counted, maybe even closer to 60 or 70. There are faceoffs at the beginning of every period, after every icing, offside, two-line pass, penalty, goal, when the puck goes into the upper netting or crowd, timeout, and when the goalie holds the puck, basically everytime play stops, which is a lot.Graham
I would be more likely to go with your second and higher guess.
Awright! Thank you one and all.
