TL3 rear channel, mounting upside down ?
What are your views on mounting my rear speakers upside down, as they are up higher on the wall when your in the seated position instead of looking at the bottom of the speaker you would see the nice curved top bit
Good idea or just keep them all the right way up?
TL350s + PSW108 + Denon AVR-2113ci
You could try it, and if you like it fine. I think you would have better results mounting them ouright on your wall and angling them down though. Of course if your furniture is very close to the wall you could place them below the furniture, and point the speakers straight up. That may work better, but who knows.
would it be unappealing if he mounted them on the ceiling pointing down, and at the proper angle to the listening position of course?2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
"WITH WILLING HEARTS AND SKILLFUL HANDS, THE DIFFICULT WE DO AT ONCE, THE IMPOSSIBLE TAKES A BIT LONGER, WITH COMPASSION FOR OTHERS. WE BUILD - WE FIGHT FOR PEACE WITH FREEDOM"Seabee Memorial, Arlington, VA -
My TL2s are mounted from the ceiling angled down and they are perfect!My H/T:
AVR: Pioneer VSX-921-K
Front L/R: Sony Towers SS-MF600H (will be upgraded to M70's or 75T's)
Center: Polk TL2
Surrounds: Polk TL2
Rear Surrounds: Sony satellites from old HTIB (will be upgraded to TL2)
Subwoofer: Sony from old HTIB (will be upgraded to DSWPRO550wi)
