How DACs work - White paper
BlueFox
I came across this while looking into their products. It is a great explanation for those new to standalone DACs, and it also applies to the DAC in a CD player.
http://www.msbtech.com/support/How_DACs_Work.php?Page=supportHome
Now I need to scrounge up $10k and buy their DAC.
Post edited by BlueFox on
I always get a laugh when people say it's just ones and zeros. Timing(jitter) is something that seems to be an important issue as of late. I think I'll be staying with the Buffalo for now. $10k and its old and out of date the day you buy it. Yikes!Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Vinyl rips: ESI Juli@24/192->Goldwave->i7 PC server -
Yeah man, I'm done buying expensive new gear. It gets obsolete within months, sometimes weeks, and then the value sinks like a rock. Higher end audio, aside from a few exceptions, doesn't hold value very well. Buy used at practically half price and save yourself a small fortune.HT SYSTEM-
lsi 9's -
Very Cool thank youDan
Thanks!
Nice looking forward to reading this.Setup:
2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI -
yeah man, i'm done buying expensive new gear. It gets obsolete within months, sometimes weeks, and then the value sinks like a rock. Higher end audio, aside from a few exceptions, doesn't hold value very well. Buy used at practically half price and save yourself a small fortune.
bingo!Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
This is why I'm allocating my 2013 funds to crossover upgrades and not a DAC. I need a good DAC more than anything at this point, but I'm content for the most part with the sound I'm getting out of the Pio. I suspect that in the next 2-3 years, there will be a wealth of USB DAC's available at VERY affordable prices as the market appears to just now be taking off.
Not a bad idea. You definitely aren't in a desperate need for a DAC with the Pioneer as your source. Not sure if the prices are going to change much in the next two years but I do hope so. There are already plenty of cheap and affordable usb dacs but it would be nice if the higher end ones drop in price.Setup:
