Where do you store your Vinyl?
    SCompRacer Posts: 9,122
    edited February 2013
    Face wrote: »
    Thanks!
    I'm not sure, but judging by how the sun affects it's leaves in the summer, it's most likely Devils Ivy. I can say, whatever it is, it's pretty resilient.
    Yeah, sunlight will increase variegation and they are a hearty plant. I thought I noticed some traces on leaves. If I am wrong about the type, the Master Gardener here will kick my arse and send me back to school!:cheesygrin:
    We have a Hoya that makes some pretty neat flowers when it gets plenty of sun.
  • RamZet
    RamZet Posts: 792
    I just got a nice basket from Target. I have the LPs simply placed in the basket standing up right.
    Just want to make sure they are not leaning on each other on a acute angle, they will bend over some time.
    B&W CM9Classé Sigma
  • Wardsweb
    Wardsweb Posts: 942
    edited March 2013
    Add another Expedit user to the list. The legs are also Ikea and I added a block of wood under the center to help support the weight.
