Polk TL3 - Can you take off the heel bit.
chen
chen Posts: 5
edited March 2013 in Speakers
I have the Polk TL3 speakers and was wondering if the bottom heel bit can be taken off? From the picture, it's the thing that holds up the speakers on a flat surface, the area below the gap. It is detachable basically.
http://www.audiophilejournal.com/wp-content/uploads/2012/05/polk-tl3-pair.jpg
Post edited by chen on
    F1nut Posts: 51,700
    edited March 2013
    That's part of the power port, you should leave it in place.
  • Face
    Face Posts: 14,340
    edited March 2013
    I believe that's part of Polk's Power Port and should be left alone.
    txcoastal1 Posts: 13,500
    edited March 2013
    I am assuming you want to angle it downwards on a bracket...would suggest a different bracket because as listed above it is part of the design and will probably change the dynamics.
    The LSiM 703 have power ports too, for bass dispersion...see pic
  • chen
    chen Posts: 5
    edited March 2013
    +1. Thanks everyone :)
