D.I.Y DVD & CD Racks....
Demiurge
Demiurge Posts: 10,874
edited June 2004 in Music & Movies
I'm curious as to how many of you have custom made DVD shelves or racks? I've always been a fan of wall mounted racks, but how plausible is it? I guess depending on how you crafted it, it could really work well. You'd most likely need brace supports, ect, correct?
I guess why i'm asking here is because i'm interested in doing something like this. I've got about 220 DVDs right now and that list seems to grow almost weekly or bi-weekly. I'm not a big fan of any of the racks at your Wal-Mart, Target, ect....
Any suggestions? Pics of your D.I.Y racks?
Post edited by Demiurge on
  • dcarlson
    dcarlson Posts: 1,740
    edited May 2004
    SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
    Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop.
  • Demiurge
    edited May 2004
    Wow...those are really cool. I may have to get those, but i'm more of a fan of darker wood, like walnut.
  • Demiurge
    edited May 2004
    What about DVDs?
  • dcarlson
    edited May 2004
    The shelves are adjustable. I can't remember how many DVDs. I'll try and give you an estimate when I get home.
    Saddly, they only comes in birch. I've had many people comment on how they really like them. My good buddy picked up a couple after he saw mine. Damn Jackass! ;)
  • Demiurge
    edited May 2004
    You may be calling me a jackass too, because depending on their capacity I may own some as well. :)
    I like the light you can put in as well. :)
  • dcarlson
    edited May 2004
    If ever I visit your place and see them on the wall, I'll definitely call you a Jackass. LOL. :D
  • pjdami
    pjdami Posts: 1,894
    edited May 2004
    It's no secret that the DIY flexy-racks are strikingly similar to the Salamander Archetype 5.0 design. So with that being said and after completing my own DIY flexy rack for the electronics, I have been pondering tackling something like this:
    http://www.salamanderdesigns.com/media/downloads/fm450.pdf
    Two nicely stained pieces of wood for the ends, 4 all-thread rods with nuts / washers for stabilization / hold it all together, and then countersink some holes into the ends and make some "runners" out of some thinner pieces of wood. I'm thinking of how to assemble the "runners" that is if glueing them after putting together with some finishing nails would do the trick. I'm thinking I could build one of these for about $50. No dust protection here though.
  • dcarlson
    edited May 2004
    It'll hold roughly 19 dvds per shelf and 6 or 7 shelves. You may be cutting it close with 2 of them.
  • Demiurge
    edited June 2004
    Thanks. Do you have a digital camera? I wouldn't mine seeing pictures of yours on the wall. Just curious how they look with the DVDs. If not, cool.
  • hamzahsh
    hamzahsh Posts: 439
    edited June 2004
    I use Mylex Media Tower shelf for DVDs and CDs. Each shelf cost me $50 Canadian and I have 4 of them lining together on side of the room. Each can hold approx. 140 DVDs. I've 508 DVD titles and lot of CDs.
    I bought it from Staples in Toronto. Love it. The depth is same as DVD keep case so they don't take lot of space.
    Wish if I had a picture to post!
    :p
    Panasonic TH-50PX80U Plasma HDTV
    Polk Audio RT800i (fronts)
    Polk Audio CS400i (center)
    Polk Audio F/X1000 (side surrounds)
    Polk Audio RTi6 (back surrrounds)
    Velodyne CHT-15 (subwoofer)
    Yamaha RX-V1400 (Pre/Pro)
    NAD C272 (2-ch Amp)
    Adcom GFA-7605 (5-ch Amp)
    Toshiba SD-3109 (DVD/CD player)
    Malata DVP-580 (Multi-region DVD player)
  • Pablo
    Pablo Posts: 723
    edited June 2004
    (I was unable to see any of the links), but if your a handy type of guy, you can always make your own fairlly easy. You can pick up a piece of birch plywood at the Home Depot for about $50. Cut it into 8 6" strips. Cut 6 of those in half (4' lengths). Attached them about 8 1/2" apart (with a top and a bottom), and you have an 8' wall of DVDs with 11 shelves 4' wide. Add some decorative molding, and you have a work of art. The birch stains nicely any color (I did my master bedroom closet in a mohagany red stain).
    This is basically what I plan on doing (but have an elaborate design that intergrates into the component shelves/speakers/sub all with mohagany edging).
    buy or build, either way, have fun.
    Denon AVR-3803
    RTi-70 Fronts
    FXi-30 Surrounds
    RTi-38 Back Surrounds
    Csi-40 Center
    PSW350 Sub
    Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
    Denon DVD-2910
    Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64
  • dcarlson
    edited June 2004
    Here you go dude.
    new.jpg 31.4K
  • HBombToo
    HBombToo Posts: 5,256
    edited June 2004
    Outstanding mr Carlson Sir...
    HBomb
    ***WAREMTAE***
  • TechChallenged
    TechChallenged Posts: 106
    edited June 2004
    Nicely done dcarlson. Dimesionally how did they install. I couldn't tell from the pics if they extend beyond the trim. The depth of the Bertby is 7 1/2" My wall depth is a 2x4 plus sheet rock for a grand total of 4"
  • pjdami
    pjdami Posts: 1,894
    edited June 2004
    dcarlson,
    Man those do look cool. What a way to save floor space. Do those just screw into the 2 X 4 studs in the wall for support?
  • Demiurge
    edited June 2004
    Here you go dude.
    Damn...Those look great. I'm going to have to give those a shot I think. :) I could always refinish them if I really wanted to. *ponders*
    Thanks for the pictures!
  • Steve@3dai
    Steve@3dai Posts: 983
    edited June 2004
    www.boltz.com
    Mmmm... I love their stuff. Got DVD racks, CD racks and my TV stand from them. Pricey, but worth it (IMO).
    LSi 9/C/FX
    Arcam AVR-200
  • dcarlson
    edited June 2004
    You could paint them but you won't be able to refinish them, they're a vinyl sort of laminate.
    I used some toggle bolts to hangs them. I'm sure you could screw them right into the studs.
    I wish they were recessed into the wall, but no.
  • brettw22
    brettw22 Posts: 7,623
    edited June 2004
    Dunno if you like the metal look, but I use two of THESE and have really liked them.
    Here's a pic of them in my place....
    The feet in the first pic look a little small, as mine have wider feet for stabilization.....
  • Demiurge
    edited June 2004
    Yeah, those don't look too bad either and there are different finishes as well. I like the look of that stuff on Boltz, but it seems too expensive. The Atlantic stuff looks more reasonably priced.
  • brettw22
    edited June 2004
    Here's the Atlantic for $20 cheaper than the other site.......add shipping (can't find how much that is without going through checkout).......might be a better deal though.....
    That one has the wider feet, but doesn't specify finish other than just showing the black. You might be able to call them and get the chrome.....
  • Demiurge
    edited June 2004
    Thanks.
    I went on EBay and checked out those wood cabinets with the 1500+ DVD capacity. Those look pretty sweet too, but I couldn't justify the shipping price.
    I'm a little torn. I really like those IKea ones that DC has, but those racks you posted aren't bad either and they're much cheaper.
    I'm moving in about a month so I have a bit of time to decide.
  • brettw22
    edited June 2004
    For me it was a cost/benefit thing. I couldn't justify paying $100-300 for a rack(s) that wouldn't hold as many as the Atlantic for $70 (I paid retail) that holds virtually 2-4 times as many DVD's.......
    I'd be all over those racks from Ikea if they were actually inset to the wall and larger, but (nothin personal DC) I don't like things(other than actual shelving) gettin all 3-Dish on my walls. Depends on how it would fit into the decor I suppose....
    Good luck
  • dcarlson
    edited June 2004
    I know what you mean, I'd love to recess them into the wall. I got one as an xmas gift from my bro and bought the other for the rest of my collection.
    It's much better than the floorstanding shelves I had, and keeping the dust out is a HUGE plus.
  • brettw22
    edited June 2004
    I've been to IKEA a lot, but I don't remember if those units having a glass door on them. I know they indicate that on IKEA's site, but I can't really tell if there is a glass door on yours or not. Take a pic from the side with the glass door open if you wouldn't mind.....
    When I was putting my collection into that website, I did notice dust on the tops of my DVD's that I hadn't really paid attention to. Nothin that a duster on a stick couldn't take care of in a few swipes.....
  • dcarlson
    edited June 2004
    So ya don't beleive me, eh? ;):p
  • brettw22
    edited June 2004
    haha......I was looking for a handle where the glass could go cuz I thought that the maple frame was fixed and the glass alone moved.
  • amulford
    amulford Posts: 5,020
    edited June 2004
    I can just see you running around in a little french maid's outfit with this big ostrich feather duster.
    Oh man, is THAT funny!;)
  • brettw22
    edited June 2004
    ****!!! That's EXACTLY why I didn't say feather duster and instead meant one of those static dusters blah blah blah.....
    Where you get that I'd be in anything like that is beyond me. I might make someone else get into that outfit (temporarily), but hey, that might be TMI......:D :D
  • hamzahsh
    hamzahsh Posts: 439
    edited June 2004
    Here is my 4 shelves holds!
    NAD C272 (2-ch Amp)
