Replacing drivers in RTI a7
tanman05851
tanman05851 Posts: 7
edited March 2013 in Troubleshooting
I have a pair of Rti a7's.One of them has a bad driver-it's not bad but it sometimes crackles at higher volumes.I think I know what driver it is but I really can't tell without swapping the suspected bad with one I know is ok.The drivers look like they take allen wrenches in the front.I have sets of both metric and english and nothing fit.Today (while at work)Polk support emailed me that it needs a 3mm hex so I ran down to the hardware store ,got home and still no luck.What am I missing here?I can't seem to find a service manual anywhere on the net.I just hope this isn't one of those "doh" moments coming up.
Post edited by tanman05851 on
    F1nut Posts: 51,947
    edited February 2013
    It's 9/64, standard for Polk these days. Not sure why someone told you 3mm.
  • pdxfj
    pdxfj Posts: 376
    IIRC my A7's used a Torx (star) screw on the drivers.
    F1nut Posts: 51,947
    Nope, 9/64 allen.
  • tanman05851
    Pretty sure it's some sort of hex.Don't have a 9/64 but I will certainly post the results.Thanks both of you.
  • zane77
    zane77 Posts: 1,696
    Finut is correct (as usual) it is definately 9/64's, I just went and checked mine
    Two Channel
  • tanman05851
    Yeppers 9/64 it is (of course.)Thanks again.Now to inform Polk tech support...
  • math wizard
    math wizard Posts: 106
    edited March 2013
    just to also chime in, it is 9/64.
    Processor - Emotiva UMC-200
    Pre-Amp (2 Ch) - Emotiva USP-1
    DSP Minidsp nanoAVR DL
    DAC (2 Ch) - Emotiva XDA-2
    Amp (Fronts) - Emotiva XPA-2
    Amp (Center/Surrounds) - Emotiva XPA-3
    CD - Emotiva ERC-1
    Fronts - Polk Audio RTi 12
    Center - Polk Audio CSi5
    Rears - Polk Audio RTiA1
    Sub - Epik Knight
    Sub EQ - Velodyne SMS-1
    Monitor - Sony XBR65X850C
    Blu-Ray - OPPO BDP-203
    Network Media Player - Chromecast Ultra
    Power Conditioner - APC H15
    Power Conditioner - Emotiva CMX-2
    PVR - DirecTV C61k
    Remote - Harmony Touch w/Hub
