is it OK to store speakers in a hot attic?
stevethebrain
stevethebrain Posts: 49
edited March 2013 in Speakers
I have a pair of Polk bookshelf speakers inside the orginal box that I'm currently not using.
don't have much storage room except for the attic.
I live in the South during the summer it hots very hot in the attic so
is it OK to store speakers in a hot attic or will the heat ruin the speakers?
Thanks STB
Samsung PN58C500/Amp: Yamaha RX-V465/Polk DSW1KProSub/DefTECH SM450/C1CC/Pro80/Sony BPX37 BD/Magnavox515/ HTPC-CPU: I3 550, 3.2 GHz/Mobo: Intel H57/RAM: 6GB DDR3 1333/HDD: 1TB/2TB Internal, 1TB external/Tuner: 1600-950 Haupague/W7 64 OS Remote: Harmony 700
Post edited by stevethebrain on
  • decal
    decal Posts: 3,205
    edited February 2013
    Probably not a good idea to store anything in an attic. I know folks do it all the time but personally, I wouldn't.
    Heat and electronics are not a good combo, no...don't.
    Toolfan66 Posts: 18,184
  • Msabot1
    Msabot1 Posts: 2,098
    Not if you ever want to use them again...same goes for extremely humid areas!
  • plainoledave
    plainoledave Posts: 408
    you'd be better off selling them and buying another set later.
  • DaveHo
    DaveHo Posts: 3,583
    Not a good idea, though car audio gets subjected to all kinds of temp extremes & doesn't die overnight. I'd be most concerned about the heat loosening the adhesive on the vinyl veneer.
  • mantis
    mantis Posts: 17,561
    No Don't do it.
    Dan
  • gdb
    gdb Posts: 6,012
    I'd say it depends on the maximum temp experienced. Your attic might never get as hot as a Baghdad living room in the summer months. If you've got drivers with the miserable failure glue, you need to JB Weld them, no matter where they're situated! :eek:
    treitz3 Posts: 20,119
    Storing speakers in an extreme storage condition like that is never a good idea. Might want to try and make room in a temperature controlled closet. If this can't be done, the advice to sell and reacquire another set later is something I would entertain if I were you.
    Have to agree. Adhesives, adhesives, adhesives. If you want to F-up a speaker, put it in about 120-30+ degree temps for a summer then bring it down hook it up blast it for a few minutes and watch "bad" things happen!
    Don't do it. I store all my stuff either in closets in the house or in a finished basement storage area.
    cnh
  • Lost240
    Lost240 Posts: 176
    edited March 2013
    I wouldn't store them up there
  • stevethebrain
    edited March 2013
    yeah I'm thinking it's not whorth taking a chance and bake these speakers.
    I guess this also rules out mounting them in the attic"s eve
    directly above a outside vent and use a a patio zone.
    Thanks Guy's STB
  • stevethebrain
    edited March 2013
    as far as selling seams like I can't give these M30s & CS1 center away.
    They are nice sounding speakers I could eventualley use (when I get a 7 channel amp.) as back surrounds and back center. I just don't want the to polute my Def. Techs. in the current room size is 12' widex 14'lenghtX8'hieght kindof small for 6.1
    maybe a larger room they won't polute the DTs. and can be used as rear fill effects speakers.
    Thanks STB
  • vinyladdict
    vinyladdict Posts: 32
    edited March 2013
    I would think it would not be very good for the foam or rubber surrounds on the speakers , this would accelerate the rotting out of the surrounds .
