Polk LSI with Boston Accoustics surrounds
stringbeanmotor
stringbeanmotor Posts: 3
edited February 2013 in Speakers
I am planning to purchase 2 LSI15 fronts, an LSI M704c center and a Marantz sr5007 receiver. I'm not going to have enough money to do the rears right away. I have an older pair of Boston Acoustics HD7 bookshelf speakers I was hoping to get away with using as the rear surrounds. I know the L/R/C have to match but not sure about the surrounds. Does anyone know if these would clash with the LSI speakers or if they would be ok temporarily? Thanks in advance.
Post edited by stringbeanmotor on
  • stringbeanmotor
    I'm still new at the higher end audio stuff. Since its a 7 channel amp, maybe ill look into bi-amping until I can purchase a good two channel for the front. Thanks for quick response.
  • PSOVLSK
    PSOVLSK Posts: 5,372
    Speakers will be getting the same power no matter how you configure it from the AVR to the speakers.
    You'll be fine with those as surrounds. From my experience I was always happy with my surrounds and thought they were doing a good job until I finally put my LSi7's as my surrounds. At that point, I realized what I was missing.
    tonyb Posts: 33,068
    The LSI's are a 4 ohm rated speaker, and your receiver can't power them accurately. You will risk doing damage to them without an amplifier. Forgo the surrounds at the moment and get a used amp for them. Hate to see you smoke a crossover in new speaks.
  • PSOVLSK
    DSkip wrote: »
    Have you considered LSiM 703's over the LSi15's? I'd think you would get better results doing this if you already have a sub in place. It will also match your center better. The LSi is voiced somewhat similarly to the LSiM, but it isn't the exact same sound.
    I thought about the voice matching of the front three as well. AND I prefer my 703 to my modded 15's. That's no disrespect to the 15's just praise for the 703.
  • stringbeanmotor
    I never even caught the 4 ohm thing. I'm glad you mentioned it. Buying another amp would put it out of my price range. Maybe ill just look into getting the rti speakers. They are a step down but they are 8 ohms so no need for the external amp off the bat. And with the $ I save I can complete the set. No need for the Bostons. Thanks guys.
