Polk LSI with Boston Accoustics surrounds
stringbeanmotor
stringbeanmotor Posts: 3
edited February 2013 in Speakers
I am planning to purchase 2 LSI15 fronts, an LSI M704c center and a Marantz sr5007 receiver. I'm not going to have enough money to do the rears right away. I have an older pair of Boston Acoustics HD7 bookshelf speakers I was hoping to get away with using as the rear surrounds. I know the L/R/C have to match but not sure about the surrounds. Does anyone know if these would clash with the LSI speakers or if they would be ok temporarily? Thanks in advance.
  • stringbeanmotor
    I'm still new at the higher end audio stuff. Since its a 7 channel amp, maybe ill look into bi-amping until I can purchase a good two channel for the front. Thanks for quick response.
  • PSOVLSK
    PSOVLSK Posts: 5,441
    Speakers will be getting the same power no matter how you configure it from the AVR to the speakers.
    You'll be fine with those as surrounds. From my experience I was always happy with my surrounds and thought they were doing a good job until I finally put my LSi7's as my surrounds. At that point, I realized what I was missing.
    The LSI's are a 4 ohm rated speaker, and your receiver can't power them accurately. You will risk doing damage to them without an amplifier. Forgo the surrounds at the moment and get a used amp for them. Hate to see you smoke a crossover in new speaks.
  • PSOVLSK
    DSkip wrote: »
    Have you considered LSiM 703's over the LSi15's? I'd think you would get better results doing this if you already have a sub in place. It will also match your center better. The LSi is voiced somewhat similarly to the LSiM, but it isn't the exact same sound.
    I thought about the voice matching of the front three as well. AND I prefer my 703 to my modded 15's. That's no disrespect to the 15's just praise for the 703.
  • stringbeanmotor
    I never even caught the 4 ohm thing. I'm glad you mentioned it. Buying another amp would put it out of my price range. Maybe ill just look into getting the rti speakers. They are a step down but they are 8 ohms so no need for the external amp off the bat. And with the $ I save I can complete the set. No need for the Bostons. Thanks guys.
