Looking for recommendations
mva5580
So right now I have a Polk rt3000p. Problem is I think it's starting to have some issues and it seems like I will need to send it in for service. I'm not sure whether or not the problem can be fixed, but let's assume it can and it's somewhere around $100 to fix it.
I've been considering just buying a new sub for the past week or two, and my budget is generally somewhere around $400 for what I would spend max on a new sub. The 2 that have caught my eye are the Klipsch rw-12d and the Polk dswpro 660wi. I've seen the Klipsch on sale at newegg for $350, and the Polk for $400.
Which route would you recommend I take? Repair the rt3000p or just pick up one of the newer subs? If the rt3000p is definitely a better sub than the other 2, I would probably send it off for service. But if the newer subs are better, I would rather just sink that ~$100 into the budget for a new one.
Post edited by mva5580 on
Klipsch on sale for $300 very often Newegg.MAIN:
Front- LsiM 707 (MIT Terminator 2 Bi-Wire),
Center- lsiM 706,
Surrounds- lsi F/X,
Power sub PSW1000,
Receiver- Harman Kardon Avr 3700,
Amp - Emo XPR-5.
Secondary (2.1):
LsiM 703,
HK Avr 3700,
Yaqin MS-30L,
Polk DSW-PRO 400. -
Newegg has the Klipsch rw-12d for $299 today again.MAIN:
Center- lsiM 706,
Surrounds- lsi F/X,
Power sub PSW1000,
Amp - Emo XPR-5.
Secondary (2.1):
LsiM 703,
HK Avr 3700,
Yaqin MS-30L,
Polk DSW-PRO 400. -
I have had a few recommendations for the Klipsch from some audio friends in the business.
I'd say if it is really around $100 fix them if you are happy with the sound. If not, I would continuously search craigslist or local classifieds for a used SVS, HSU, etc. You can sometimes find GREAT deals on lightly used higher end gear on CL. I would personally rather spend $300-400 on a used SVS than any new klipsch or polk. IMOLiving Room:
Paradigm Cinema 330 x 3, Pioneer 9040TXH
Media Room:
RTi12, CSi5, F/Xi3, RTi4, Onkyo SR805, SVS PB12 Plus/2, HSU MBM
