5.1 1 sounds lower then the other...
so i recently purchased this polk audio product http://www.newegg.com/Product/Product.aspx?Item=N82E16882290232
and i just found out that one of the Speaker is lower then the rest, so should i call polk audio for a exchange or Newegg ? it's not 3days old and it failed -_- god.... Thanks for the help
i only wish to replace that one speaker so if i call newegg they will probably tell me i need to send them all the speakers..
Swap the speakers around, and see if the same speaker is always lower. Generally, a speaker either works, or it doesn't. For a speaker to work, but just be lower than identical speakers, would seem to be rare.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I did that's the 1st thing I did .
Okay. Check with both support groups for what to do.Lumin X1 file player, Westminster Labs interconnect cable
