Building new system with Tl350, Denon 2113ci
raymate
raymate Posts: 26
edited March 2013 in Speakers
Is anyone running the Tl350 with a Denon.
I'm looking at the AVR-2113ci
Anyone using this amp?
TL350s + PSW108 + Denon AVR-2113ci
  • raymate
    raymate Posts: 26
    edited February 2013
    Forgot to add I may also look at the AVR-1913
  • Irrenhaus
    Irrenhaus Posts: 1,105
    I use a Adcom 585 on My 12's and I am happy with that...
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
    Welcome to Club Polk!
    OP is running a Blackstone satellite system. You don't need an Adcom for that. But I would consider the higher Denon model and even the 3XXX series above that because that has the pre-outs which you could use to upgrade your system in the future and since you're not going to be using a power amp at this point you'd want your Denon to have enough power reserves. So no lower than the 2xxx series and preferably the 3xxx!
    Actually, IMHO, Denon and Polk are a good match! Should sound nice!
    cnh
  • nwohlford
    nwohlford Posts: 700
    I would look at the Marantz sr-5007 as well which is very similar to the Denon 2313. It does add the preamp outs, but I doubt you would need an amp with the tl-350s unless you have a huge room, but if you have a huge room you would probably not be getting the tl-350s.
  • raymate
    raymate Posts: 26
    This sounds good, the reason I was tempted by the 1913 is I can get a good deal on that right now the 2113 is not such a great deal right now (over in Canada anyway)
    From your comment I may hold out for the 2113.
    I can take my time building this system as it's my secondary system in our living room, in my basement I have an old school Denon AVC-A1SE in gold that is used for movies and music
    I dont actually have the TL350 yet, getting them next week, have approval from the other half as they are tiny and will not been seen to much so not upset the decor ;)
    Not actually heard them yet, but I can not really find any bad reviews on them and for what they are going to used for should do nicely, 50% music (straight stereo), 35% TV (surround) and 15% gaming (surround)
  • raymate
    raymate Posts: 26
    Not seen much on that amp, it has one small display.
    Is it good for straight stereo as well, it needs to be great for music.
    I actually have a nice high end Marantz CD player
  • raymate
    raymate Posts: 26
    Got the TL350 and a PSW108 sub tonight, next couple of week I shall get the amp
  • raymate
    raymate Posts: 26
    edited March 2013
    Thanks for all your input I ended up with the AVR-2113ci installed and it all runs fine
