Hooking up two Polk PSW200's
ma61
ma61 Posts: 5
I searched but cannot seem to find anything that is specific to my issue.
I have two Polk PSW200's, and I would like to run them both at the same time.
I have a Y cable from the sub out on my Denon avr1312, which I have been running one psw200 with.
But I just got another one psw200 today and want to run them both.
So I tried to just go from line out on the first sub, to line in on the second. But no sound from the second sub.
So I got two more Y cables.
There is one Y cable from the "sub out" on the amp, with two more Y cables plugged
into that, with RCAs running to both subs from those.
Now I have sound on both subs.
But, when I set the level on one sub, and go to turn the other one to match, it is not as loud.
AND the first sub decreases in volume.
Any help guys? Thanks in advance
Post edited by ma61 on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited February 2013
    Hello ma61,
    It is possible the problem is being caused by cancellations between the two subs. Try adjusting the "variable phase control" of one of the subs and see if this changes the perceived output level. How are you determining the levels? SPL meter? Or, just by listening?
    Regards, Ken
  • ma61
    ma61 Posts: 5
    Hello ma61,
    Regards, Ken
    I am just judging this by ear.
    The phase would need to be the same on each sub correct?
  • seabeerob213
    seabeerob213 Posts: 1,843
    hook one up through the speaker level inputs
  • [Deleted User]
    It might be helpful if you disconnected all of the speakers and leave the subs operating. Then begin to adjust the variable phase controls on one unit and listen to how the bass changes. Differences in room placement and distances to your listening position can effect how the bass waves interact.
  • ma61
    ma61 Posts: 5
    What do you mean?
  • ma61
    ma61 Posts: 5
    I will have to try that once I get home from work.
  • seabeerob213
    connect your front speaker ou from the AVR into the speaker level in on the sub, then connect the speakers to the speaker level out from the sub, that way youre not splitting the signal from the AVR
  • HTguru1982
    HTguru1982 Posts: 1,066
    Use the Y Splitter from the receiver and run each separate cable into the "Left/Mono" inputs on your subs. You shouldn't have to use the output jacks on the subs to connect both of them.
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
