Hooking up two Polk PSW200's
ma61
I searched but cannot seem to find anything that is specific to my issue.
I have two Polk PSW200's, and I would like to run them both at the same time.
I have a Y cable from the sub out on my Denon avr1312, which I have been running one psw200 with.
But I just got another one psw200 today and want to run them both.
So I tried to just go from line out on the first sub, to line in on the second. But no sound from the second sub.
So I got two more Y cables.
There is one Y cable from the "sub out" on the amp, with two more Y cables plugged
into that, with RCAs running to both subs from those.
Now I have sound on both subs.
But, when I set the level on one sub, and go to turn the other one to match, it is not as loud.
AND the first sub decreases in volume.
Any help guys? Thanks in advance
Post edited by ma61 on
Hello ma61,
It is possible the problem is being caused by cancellations between the two subs. Try adjusting the "variable phase control" of one of the subs and see if this changes the perceived output level. How are you determining the levels? SPL meter? Or, just by listening?
Regards, Ken -
Kenneth Swauger wrote: »Hello ma61,
Regards, Ken
I am just judging this by ear.
The phase would need to be the same on each sub correct? -
hook one up through the speaker level inputs2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
"WITH WILLING HEARTS AND SKILLFUL HANDS, THE DIFFICULT WE DO AT ONCE, THE IMPOSSIBLE TAKES A BIT LONGER, WITH COMPASSION FOR OTHERS. WE BUILD - WE FIGHT FOR PEACE WITH FREEDOM"Seabee Memorial, Arlington, VA -
It might be helpful if you disconnected all of the speakers and leave the subs operating. Then begin to adjust the variable phase controls on one unit and listen to how the bass changes. Differences in room placement and distances to your listening position can effect how the bass waves interact.
seabeerob213 wrote: »hook one up through the speaker level inputs
What do you mean? -
Kenneth Swauger wrote: »It might be helpful if you disconnected all of the speakers and leave the subs operating. Then begin to adjust the variable phase controls on one unit and listen to how the bass changes. Differences in room placement and distances to your listening position can effect how the bass waves interact.
I will have to try that once I get home from work. -
connect your front speaker ou from the AVR into the speaker level in on the sub, then connect the speakers to the speaker level out from the sub, that way youre not splitting the signal from the AVR2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
Use the Y Splitter from the receiver and run each separate cable into the "Left/Mono" inputs on your subs. You shouldn't have to use the output jacks on the subs to connect both of them.Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD
