5.25 to 6.5 how do i make it happen?
ipartywhenuhurt
Have sr6500 and I need to fit them in 5-1/4 any ideas on custom build adapters etc?
Depends on how much space you got in your doors, between door skin and (plastic) door panel and how your grill is/fits/installs.
I'd look for these anwsers in your car-specific forum.2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1 -
TV: Philips 42" LCD 1080p
Front Speakers: Polk Audio RT800i
Center Speaker: Polk Audio CS1
Surround Speakers: Polk Audio R50's powered of Denon AVR
Subwoofer: Polk Audio DSW pro500
AVR: Denon 3801
DVD Player: Denon DVM 745 upscale 1080p
Sat: Directtv HD 10
Front Speakers Amp: Rotel RB 890
Center Speaker amp: Rotel 970 BX -
I have built them with 2 layers of plywood its a 2 piece setup that screws down in the 5" holes and further up it has a mount for the 6" driver
How are you on depth? Are you completely against trimming?
If you have the depth,m a jig saw will make it work. I have put 6x9s in the front doors of a Saturn, and have put 10" woofers in the doors of a F150, and needed nothing more than a jigsaw to make the hole.
