5.25 to 6.5 how do i make it happen?
ipartywhenuhurt
ipartywhenuhurt Posts: 130
edited February 2013 in Custom Fabrication
Have sr6500 and I need to fit them in 5-1/4 any ideas on custom build adapters etc?
Post edited by ipartywhenuhurt on
  • Vital
    Vital Posts: 747
    edited November 2011
    Depends on how much space you got in your doors, between door skin and (plastic) door panel and how your grill is/fits/installs.
    I'd look for these anwsers in your car-specific forum.
    2008 Nissan Altima
    Kenwood DNX 5140
    Arc Audio IDX and XEQ
    Polk Audio SR6500 active and SR124-dvc sealed
    Polk Audio PA500.4 and PA1200.1
  • greg2350
    greg2350 Posts: 544
    TV: Philips 42" LCD 1080p
    Front Speakers: Polk Audio RT800i
    Center Speaker: Polk Audio CS1
    Surround Speakers: Polk Audio R50's powered of Denon AVR
    Subwoofer: Polk Audio DSW pro500
    AVR: Denon 3801
    DVD Player: Denon DVM 745 upscale 1080p
    Sat: Directtv HD 10
    Front Speakers Amp: Rotel RB 890
    Center Speaker amp: Rotel 970 BX
  • 20hz
    20hz Posts: 636
    edited January 2013
    I have built them with 2 layers of plywood its a 2 piece setup that screws down in the 5" holes and further up it has a mount for the 6" driver
  • Anthony Hinton
    Anthony Hinton Posts: 107
    How are you on depth? Are you completely against trimming?
  • dudeinaroom
    dudeinaroom Posts: 3,609
    If you have the depth,m a jig saw will make it work. I have put 6x9s in the front doors of a Saturn, and have put 10" woofers in the doors of a F150, and needed nothing more than a jigsaw to make the hole.
