daisy chainable
Willow
Willow Posts: 11,257
edited June 2004 in Electronics
what does this mean ??
Post edited by Willow on
  • I-SIG
    I-SIG Posts: 2,243
    edited June 2004
    Say you are putting together a "building-wide" audio system with all speakers playing the same thing. However, it is a decent size place and it wouldn't make sense to try and get one amp to feed everything in the building. What one can do is "daisy chain" the amps together, i.e. in this case take RCA-level signal/wire from amp to amp to amp, etc. through the structure rather than having to split the output from the source/pre-amp five ways.
    Does that make sense?
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • Willow
    edited June 2004
    sure does thanks !!! I thought thats what it was but having the example cleared everything
  • shack
    shack Posts: 11,154
    edited June 2004
    More than likely this refers to "Jukebox" CD/DVD players. This is a mentod where you can hook up more than one player together and control them all from one unit...be it a single disc player or a changer or one of the jukeboxes.
  • Willow
    edited June 2004
    this had to do with an amp by cambridge soundworks it said it was daisy chainable
  • pixiedave
    pixiedave Posts: 227
    edited June 2004
    its also a a term used in concert taping, in a soundboard feed, the first recording deck gets the board signal, and then a line out from deck 1 to deck 2 etc. same idea
    You never blow your trip forever! < Daevid Allen
