LSi15 Efficiency Rating
Ocezam
Ocezam Posts: 52
edited February 2013 in Speakers
Does anybody here know under what circumstances Polk measures their speakers efficiency? My LSi's (15's) are rated at 88db according to Polk. Is that measured in an anechoic chamber or a "typical room"? Most mfg state how it's measured. I'm unable to confirm either way.
Thanks...
"The ear is not a microphone, the brain is not a tape recorder, and measurements are limited in describing subjective quality." Nelson Pass
2 Channel:
XDA-2, Modified Jolida JD502P (2 ea), Polk LSiM705
Theater:
Onkyo TX-NR3009 with 9 active channels, Emotiva XPA-5, MartinLogan Encore TF Center Channel, Polk M70 Mains, M40 Wides, M30 Heights, FXi A4 Surrounds, Custom built 18" sub, Mitsu 73" DLP
Post edited by Ocezam on
  • steveinaz
    steveinaz Posts: 19,546
    Anechoic, with the mic at 1 mtr. I pretty certain all sensitivity measurements are done this way.
    F1nut Posts: 51,997
    No, they don't.
    Just out of curiousity, why is this important to you ?
  • Face
    Face Posts: 14,340
    Should be the same no matter where it's measured, room, chamber, etc...
  • Ocezam
    Ocezam Posts: 52
    No, they don't.
    Yeah you're probably right, I wish they would.
    tonyb wrote: »
    Curiosity mostly
    Face wrote: »
    No it's not the same. Some manufacturers will give both ratings. An "in room" measurement will give a rating four or five points higher than in an anechoic chamber because of room reflections.
    2 Channel:
    Theater:
  • Face
    Face Posts: 14,340
    In room will only boost low frequencies, not the entire speaker. A speaker rated -3dB @ 30hz in room will be -3dB @ 40+ in an anechoic chamber. Which leads me to, many times "in room" measurements are very generous and makes me wonder if they measured the speaker in a closet.
  • Ocezam
    Ocezam Posts: 52
    Face wrote: »
    Funny. And your right. If you don't know what the "room" that was used is like, the results are still relatively useless.
    Anyway, thanks for the replies.
    2 Channel:
    Theater:
