starting out
Gunner105
Gunner105 Posts: 5
I'm looking at a set of TSI400's, a CS20 and a PSW505. My question is would an Onkyo TX-NR616 have enough power to get good sound from this setup? Knowing nothing about wires and stuff I'm looking at 16ga wire and seawell deadbolt banana plugs.
I've never had anything beyond computer speakers or a bookshelf system. This system is going to be for music and movies. Not sure if I should get another set of speakers for the rear, trying to stay within a set budget right now.
thanks! :cheesygrin:
Post edited by Gunner105 on
    txcoastal1 Posts: 13,512
    edited February 2013
    Congrats you'll be fine unless u run her ear bleeding
  • cfrizz
    cfrizz Posts: 13,415
    +10 What Lasareath said. Welcome to Club Polk!
  • seabeerob213
    seabeerob213 Posts: 1,843
    go for monoprice plugs in that price range, those sewell are brass, not copper, i have some and dont really care for them
  • cowtrimmer
    cowtrimmer Posts: 201
    The 616 will have enough power, but for $150 more I would go to amazon and get a TX-NR709 or $160 more will get you a 717. It will have pre outs like lasareath mentioned and save you from upgrading down the road.
  • Gunner105
    Gunner105 Posts: 5
    Thanks all, your input is really appreciated!!!!
    I'm checking into monster cable and I'll look at the monoprice plugs also.
    The 717 would mean waiting another 3 months, I'll have to do a little more figuring.
  • Gunner105
    Gunner105 Posts: 5
    Yep,not much difference between them and amazon. Thanks!
  • Jimbo18
    Jimbo18 Posts: 2,349
    +1 I don't like the Sewell either.
  • seabeerob213
    i have some of those monster plugs as well, easy to use, but hard to fit with 11 AWG that i have, expensive too for what they are, i paid 20 for 2 pair, although the monster are very secure as well, they didnt state whether they are brass or copper, and i didnt feel like running a file over one to find out
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    Got my 717 from newegg.com $499 shipped. Keep checking the site as the price changes often.
  • fbm211
    fbm211 Posts: 1,488
    Furez makes some pretty good pure copper bananas as well as silverplated.DH labs is also very good.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • seabeerob213
    fbm211 wrote: »
    hit up helopilotdoug for those plugs, he has aa site, http://www.douglasconnection.com/ that he runs, mention your a member and he'll shave off a little bit
  • teekay0007
    teekay0007 Posts: 2,289
    At newegg, you can request a price alert email and they'll notify you when the item's price hits that point. That way you don't have to keep checking back and wondering if you missed a price reduction. It works well, I used it for my DSWPRO550wi's.
  • John K.
    John K. Posts: 822
    Gunner, welcome to Club Polk. The Onkyo 709 at Accessories4less for about $440 including shipping is an outstanding buy. This unit is factory refurbished and carefully checked and is even more likely than a brand-new unit to be trouble-free.
    As to a comparison with the 717, the 709 has been a frequent suggestion of mine, but I consider the 717 to be unacceptable. In a rather bizarre marketing move(apparently intended to separate the 818 more clearly from it)the key Audyssey provision was downgraded two steps from MultEQ XT to 2EQ, which doesn't apply room EQ to the sub channel, which probably is the area that needs it most.
