decently priced 2 or 4 channel 4ohm 100-150 watt per channel amp
bevo
bevo Posts: 306
edited February 2013 in Wanted (WTB) Classifieds
I'm needing a cheaper 2 or 4 channel amp to push some 4 ohm tacticle transducers. I would like to get at least 100 watts per channel but preferably 150.
Would spend around 150$ for a 2 channel and up to 250$ for a 4 channel.
Denon 1909, want to upgrade for pre outs
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
Panasonic plasma 50 inch
Buttkicker(don't use or need it anymore since getting the Ultra)
Post edited by bevo on
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited January 2013
    Your budget is just a hair below the threshold of getting a very nice amp! In the 200.00 range you can get a parasound 800 series or the like, that will give you want and great sound.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    tonyb Posts: 33,072
    edited January 2013
    Look at pro amps to run bass shakers, cheap and lots of power.
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited January 2013
    Don't need anything high end to run bass shakers as long as you don't overdrive them.
  • bevo
    bevo Posts: 306
    I bought an adcom 5400 from someone one here. Works great with them. thanks for the advice.
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
