decently priced 2 or 4 channel 4ohm 100-150 watt per channel amp
bevo
I'm needing a cheaper 2 or 4 channel amp to push some 4 ohm tacticle transducers. I would like to get at least 100 watts per channel but preferably 150.
Would spend around 150$ for a 2 channel and up to 250$ for a 4 channel.
Denon 1909, want to upgrade for pre outs
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
Panasonic plasma 50 inch
Buttkicker(don't use or need it anymore since getting the Ultra)
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
Post edited by bevo on
Your budget is just a hair below the threshold of getting a very nice amp! In the 200.00 range you can get a parasound 800 series or the like, that will give you want and great sound.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Look at pro amps to run bass shakers, cheap and lots of power.HT SYSTEM-
lsi 9's -
Don't need anything high end to run bass shakers as long as you don't overdrive them.
I bought an adcom 5400 from someone one here. Works great with them. thanks for the advice.Denon 1909, want to upgrade for pre outs
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
