Will the G12 grill fit properly on a MM2124?
Systems
Systems Posts: 14,873
edited June 2004 in Car Subwoofer Talk
I wanted to know if the grille on the attached image (G12) would fit on this http://www.polkaudio.com/car/product.php?name=mm2124 subwoofer.
Any help is greatly appreciated, thanks.
Testing
Testing
Testing
  • Systems
    edited May 2004
    Nevermind, I just read the following on the specs...
    "Anti-Resonance Trim Gasket for tight fit with G Series Grilles, removable for over 1/4² of installation flexibility. "
    I also found this picture on the website...
    Testing
    Testing
    Testing
  • neomagus00
    neomagus00 Posts: 3,899
    edited June 2004
    wow, that one was easy :)
