RT 800i tweeter replacement help
adrsuhen
adrsuhen Posts: 13
edited January 2013 in Troubleshooting
Where I can get replacement for my RT800i's tweeters, and I can not find instruction to replace those.
Thank you : Andre
Post edited by adrsuhen on
  • ken brydson
    ken brydson Posts: 9,016
    edited January 2013
    adrsuhen wrote: »
    Thank you : Andre
    Call Polk CS at the # in the top right of the screen. They'll hook you up. Mention your a forum member for a nice discount.
  • adrsuhen
    adrsuhen Posts: 13
    edited January 2013
    Thank you, I will call tomorrow.:smile:
  • adrsuhen
    adrsuhen Posts: 13
    edited January 2013
    The price way to high for me:sad:
    VR3 Posts: 29,534
    edited January 2013
    I would look for a set of used RT35i - they usually go for around $100.00
    As a minimum you will have a back up tweeter. I am not sure if the woofers are a different ohm rating or not but at $100 you will have a potential nice selection of parts.
    To remove the tweeter, you will remove the baffle, take a flat head screw driver and there is a slot to the right side of the tweeter that you will wedge the screwdriver into and lift upwards. I have posted a video online...
    Best of luck!
  • adrsuhen
    adrsuhen Posts: 13
    edited January 2013
    Thanks for the advice, or can I use my monitor 40's tweeters on my rt800i? Appearance is not really matter for me because I can hide it behind the grill.
