Hook up Sub to amp
jmotorman
jmotorman Posts: 3
I uploaded two photos to show the sub. Trying to hook up this sub to a Onyko Intergra DTR 6.3 receiver. I think I need a amp to do this but want to make sure. Thanks. The sub only has a connection for a positive and neg. wire connection on the back. One pair. Any help greatly appreciated. Jerry
Post edited by jmotorman on
  • Conradicles
    Conradicles Posts: 6,340
    edited January 2013
    Yes Sir you need an amp to do it properly. I had that sub back in the day:biggrin:
  • jmotorman
    jmotorman Posts: 3
    edited January 2013
    SO, TO DO this right, I need to come out of the sub, into a amp, out of the amp into the receiver. Thanks so much.
  • jmotorman
    jmotorman Posts: 3
    edited January 2013
    How big a amp do you suggest, wattage wise? By the way, great verse, I am not ashamed of the gospel of Christ.
  • ntculenuff
    ntculenuff Posts: 1,146
    edited January 2013
    look up the specs on the sub and you will know what size amp is suggested i would say 100-200 watts would bee good. Also keep in mind that the jl is a car audio sub and is a 4ohm speaker (possibly 3ohm they did some for a bit). Again look up the specs on it. you'll want to make sure that you have that sub crossed over too. either use the lfe filter in the receiver if it has one or get a sub amp that has one built in. just make sure you have a crossover on it. depending on your setup i would at least make sure it is 80hz or lower, i find 80hz tends to be a little boomy personally, it all depends on your setup.
    Receiver sub out> sub amp> sub
    Speakers:
    Definitive BP7001sc mains
    Definitive C/L/R 3000 center
    Polk RT800i's rears
    Definitive supercube I Sub
    Audio:
    Onkyo TX-NR3010
    Emotiva XPA five Gen 3
    OPPO BDP-103 CD, SACD, DVD-A
    Video:
    Panasonic TC-P65ZT60
    OPPO BDP-103 Bluray
    Directv x's 2
  • Anthony Hinton
    Anthony Hinton Posts: 107
    edited January 2013
    jmotorman wrote: »
    Yep, and nope.. Reverse that entire statement.
  • Anthony Hinton
    edited January 2013
  • Anthony Hinton
    edited January 2013
    ntculenuff wrote: »
    BUT.... more is almost always better.
  • ntculenuff
    edited February 2013
    true, to an extent. but yeah always nice to have more head room to play with :mrgreen:
    Speakers:
    Polk RT800i's rears
    Audio:
    Onkyo TX-NR3010
    Video:
    OPPO BDP-103 Bluray
    Directv x's 2
