Hook up Sub to amp
jmotorman
I uploaded two photos to show the sub. Trying to hook up this sub to a Onyko Intergra DTR 6.3 receiver. I think I need a amp to do this but want to make sure. Thanks. The sub only has a connection for a positive and neg. wire connection on the back. One pair. Any help greatly appreciated. Jerry
Post edited by jmotorman on
Yes Sir you need an amp to do it properly. I had that sub back in the day:biggrin:
SO, TO DO this right, I need to come out of the sub, into a amp, out of the amp into the receiver. Thanks so much.
How big a amp do you suggest, wattage wise? By the way, great verse, I am not ashamed of the gospel of Christ.
look up the specs on the sub and you will know what size amp is suggested i would say 100-200 watts would bee good. Also keep in mind that the jl is a car audio sub and is a 4ohm speaker (possibly 3ohm they did some for a bit). Again look up the specs on it. you'll want to make sure that you have that sub crossed over too. either use the lfe filter in the receiver if it has one or get a sub amp that has one built in. just make sure you have a crossover on it. depending on your setup i would at least make sure it is 80hz or lower, i find 80hz tends to be a little boomy personally, it all depends on your setup.
Receiver sub out> sub amp> subSpeakers:
Definitive BP7001sc mains
Definitive C/L/R 3000 center
Polk RT800i's rears
Definitive supercube I Sub
Audio:
Onkyo TX-NR3010
Emotiva XPA five Gen 3
OPPO BDP-103 CD, SACD, DVD-A
Video:
Panasonic TC-P65ZT60
OPPO BDP-103 Bluray
Directv x's 2 -
Yep, and nope.. Reverse that entire statement. -
oops
ntculenuff wrote: »look up the specs on the sub and you will know what size amp is suggested i would say 100-200 watts would bee good.
BUT.... more is almost always better. -
true, to an extent. but yeah always nice to have more head room to play with
Anthony Hinton wrote: »BUT.... more is almost always better.Speakers:
Polk RT800i's rears
Audio:
Onkyo TX-NR3010
Video:
OPPO BDP-103 Bluray
Directv x's 2
