Harbeth HL-P3ES-2
mrbiron
mrbiron Posts: 5,721
edited January 2013 in Speakers
I'm looking into moving away from the RTiA5's for my 2 chan speakers and looking into a pair of used Harbeth HL-P3ES-2 that showed up locally.
I have a couple questions. First and foremost, what is going rate on a speaker like this used?
Also, i'd be using them in a roughly 12' x 15' room with my associated Anthem gear. Are these speakers too small for this room? I don't know the sound of these speakers so knowing the Anthem sound, does this seem like a decent pairing? I'd mostly be listening to vinyl with the occasional internet radio/mp3/flac. I've read that the bass response in smaller rooms is quite good but, again, my room seems slightly larger than a "small room" so would i need a sub?
Any info/suggestion would be appreciated.
Thanks.
    edited January 2013
    I'm no expert on Harbeths, there are others (steve) that own some larger models who should be PM-ed, but aren't these more like a NEAR field monitor in size and function. An odd choice to replace towers that reach in the the 40hz range. Definitely going to need a sub!
    More will chime in!
    cnh
  • mrbiron
    edited January 2013
    Yeah i here ya. All of the reviews i've read are very positive but i find that most people seem to have them in 10x10 rooms IE, office system. I'm just looking to try the next thing. Surprisingly the A5's are a very capable speaker for what they are.
    I ran the A5's with a sub but prefer them without. The reviews of the Harbeths all say that the bass response is quite good which makes the change much easier on the wallet.
  • steveinaz
    steveinaz Posts: 19,546
    edited January 2013
    Depends on how loud you want to listen. I have found with my 7es-3's that they play cleanly far louder than the impressions I was given, and I have a large room. They haven't ran out of steam on me yet, and I listen pretty damn loud on occassion.
    Pricing: They hold their value well, like the Harley Davidson of speakers; so while you can pick them up cheaper used, it won't be quite the discount you might expect.
    Bass: I use a sub with my 7es-3's, but in all honesty I'd be perfectly happy with them minus the sub. The 7es-3 is down 3dB @ 46Hz.
    If you're a vocal accuracy fanatic, you'll love them. Harbeth gets the midrange/treble more realistic than I've ever heard in 37yrs of this hobby. I picked up my 7es-3's used, and Harbeth is still honoring the warranty! I may in the future, go ahead and upgrade to the Super HL5 Harbeth.
  • audiocr381ve
    audiocr381ve Posts: 2,588
    edited January 2013
    Off-topic but damn I love the classic look of Harbeth speakers.
  • steveinaz
    edited January 2013
    They are truly a "get off the merry-go-round" speaker, IMO.
  • audiocr381ve
    edited January 2013
    steveinaz wrote: »
    I'd like to get off the merry-go-round. Can't wait to get my ears on a pair of Harbeths.
