Sub Woofer plugged into surge protector/power bar?
Cuchulain
My powered sub woofer has died. A friend says I should have had it plugged into a surge protector. Are there fuses in these? Wall socket is good; power indicator is not coming on. Is this likely a simple fix? Thanks in advance for any thoughts.
AVR: Integra DTR-50.4
TV: LG 50PS70
DVD/CD/BR: OPPO BDP 93
MAINS: Polk RTiA7
CENTER: Polk CSiA6
Heights: Polk VS 625RT (in wall)
SURROUNDS: Polk TC60i (in ceiling)
REARS: Polk R1
SUB: Polk PSW 125
TV: LG 50PS70
MAINS: Polk RTiA7
CENTER: Polk CSiA6
REARS: Polk R1
SUB: Polk PSW 125
Post edited by Cuchulain on
It's 10 or 12 years old now I guess. I'm thinking now if it's 50 bucks or more to fix I could throw that into upgrading. I'll open it up and have a look.AVR: Integra DTR-50.4
TV: LG 50PS70
MAINS: Polk RTiA7
CENTER: Polk CSiA6
REARS: Polk R1
SUB: Polk PSW 125 -
Yup. Fuse attached to the circuit board. And blown. Came out easily with a slot driver. I guess I'll get that surge protector while I'm at it. Thanks!AVR: Integra DTR-50.4
TV: LG 50PS70
MAINS: Polk RTiA7
CENTER: Polk CSiA6
REARS: Polk R1
SUB: Polk PSW 125 -
I have a Monster Power HT protector (not sure of the model) that has a "safelite" for my set up but the sub is plugged into an adjacent wall and didn't really think of protecting it.AVR: Integra DTR-50.4
TV: LG 50PS70
MAINS: Polk RTiA7
CENTER: Polk CSiA6
REARS: Polk R1
SUB: Polk PSW 125 -
Just put in a new fuse and it's not coming on. Some other damage has been caused.AVR: Integra DTR-50.4
TV: LG 50PS70
MAINS: Polk RTiA7
CENTER: Polk CSiA6
REARS: Polk R1
SUB: Polk PSW 125 -
Yup, I've got about 3 old subs laying around all dead to the world waiting for me to fix them up...and it's probably not worth fixing old subs anyway. I just picked up a Polk 505, not the best rated but has a warranty and Amazon delivered it for $180.ooMain Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's. -
I figured that .
If the driver is good you could get a ebay amp to drive it just get one with as much or more power than the dead oneJust put in a new fuse and it's not coming on. Some other damage has been caused. -
I think that your friend was wrong!My powered sub woofer has died. A friend says I should have had it plugged into a surge protector. Are there fuses in these? Wall socket is good; power indicator is not coming on. Is this likely a simple fix? Thanks in advance for any thoughts.
Sub-woofers are very robust units. If a surge took-out a sub, it would also toast lots of other equipment. -
Looks like i'm in the market for a new one.AVR: Integra DTR-50.4
TV: LG 50PS70
MAINS: Polk RTiA7
CENTER: Polk CSiA6
REARS: Polk R1
SUB: Polk PSW 125 -
Parts Express has sub amps for sale on their site. You might be further ahead to buy a brand new sub though.Main System 2.2:
Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
(2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
Home Theater 5.2:
Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
Winter Residence 2.1 (laptop system):
Yamaha RX-485 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200 -
Speedskater wrote: »I think that your friend was wrong!
His friend only suggested that it should be plugged into a surge protector, what is wrong about that? -
I read it as: his friend said it failed because it was not plugged into a surge protector.
A whole house surge protector is the best way to go.
On page 30 of this white paper, Jim Brown writes about point of use surge protectors:
Power and Grounding for Audio and Video Systems
A White Paper for the Real World – International Version
Jim Brown
Audio Systems Group, Inc.
Shunt mode devices can cause damage to equipment if, during a surge event (lightning,
power transient) they conduct the surge to the ground conductor at some point other
than the building common point. When that happens, the ground conductor takes the
full weight of the surge, and thanks to resistance and inductance in the ground
conductor(s), the voltage rises to a very high value. If that ground conductor is connected to
other equipment (for example, by the shield of an audio or video cable), or even capacity-
coupled by means of an Ethernet cable connecting two pieces of equipment, it is
very likely that one or both pieces of equipment will fail destructively, because the
other equipment is bonded to ground at a different point in the building. In other
words, it is the difference in the voltage between the two pieces of interconnected
equipment that causes the failure. To avoid this failure mode, shunt mode suppressors
must be bonded to a ground only to the building common point.
http://www.audiosystemsgroup.com/SurgeXPowerGround.pdf -
Dang -- I had the same thing happen last week. My Martin Logan Dynamo sub went Pop. Took out the fuse; it was fried. Replaced it (twice) and it fried again each time I turned it back on. Talked to Martin Logan and their guess was the power supply had gone bad, and at $170 to replace, not worth it for me, which is a shame, because it is an awesome sub.
Anyone have any other (Free/cheap) ideas I can try? would love to find a way to rejuvenate this sub.5.1 theater - Pioneer SC-07, Mirage OMD-CC center, 4 x Mirage Omnisats, Boston Acoustics VPS-210 sub
2.1 living room - NAD 7400 integrated, 2 x Platinum Audio Duos, MIT Terminator4 cables
2.1 bedroom- Arcam Solo, 2 x Mirage OMD-5's
FOR SALE - Genesis Servo-10 sub, Genesis Servo-12 amp; Martin Logan Dynamo sub; Mirage MM-6 sub; Harman Kardon DPR-1001 7.1 receiver
