Fixing up my old Mini Monitors - crossover question
LoTek
I have a pair of Mini monitors that I purchased back in 95 (I think).
One of the tweeters blew out and I was going to trash them. Instead, they got cannibalized a little bit.
Now I'd like to get them back into service. I have located some replacement tweeters (SL4000) and the 5.25" drivers are in good shape. (MW5505).
The crossover components are long gone. I think it was an RE1500-1.
Does anyone know the crossover point? I'm guessing it was at 3Khz.
I can rebuild a crossover if I know the crossover point or at least be close
any information is appreciated, thank you.
Post edited by LoTek on
Turns out the replacements are no longer available!
I need both tweeters or a comparable substitute.
Can anyone tell me the specs on a SL4000 tweeter?
The cutouts are 2" in diameter.
I need to know some info such as the impedance (4 or 8?)
I also found the schematic for the crossover (one 3.3 uF cap and a 0.2 mH inductor coil). I got it all back together but I found that both tweeters are gone. I have a generic, harsh tweeter in there for now but I'd like to get a silk-dome installed
ANY help is appreciated
thanks, -
The DCR on mine are 2.5 ohms so i am guessing the impedance would be about 4 ohms, I had always thought they where made by peerless like the ones used on the monitor 10There is no cure....
Luxman M117, SDA SRS 2.3, rear monitor 10, back rear bose 4.2, valodyne sub and 2 Onkyo m-504 amps Onkyo TX-NR709
8mm, 7.62x39mm -
try partsexpress
cool, thanks guys
I have come across the same question,thanks too
