I would like everyone's input (home theater speakers related)
whitecamaross
whitecamaross Posts: 219
Good evening,
I have recently purchased a rotel rmb 1095 from a fellow forum member. That being said, i currently have the following set up:
1. Onkyo txnr 1009
2. panamax power conditioner
3. ps3
4. POLK AUDIO lsic (center), lsi9 (fronts), polk psw 1000 subwoofer, polk audio FXI A6 surrounds, LSI7'S as front heights ( i dont have space for front width channels)
5. EPSON thx 8700ub projector with 106 inch elite motorized screen.
Anyhow, my dilemma is that i have been using the onkyo 1009 unit pushing 7 channels. The rotel amp is a 5 channel amp so i am highly considering just taking down the lsi7s and use them as surrounds instead and eliminating the fxia6 surrounds completely.
Another possible scenario is to just power my main 5 speakers with the rotel and have the onkyo power up my front heights?
My concern with that last idea is that the rotel will crank up pretty loud making the front heights almost vanish because the onkyo won't be capable of keeping up with it.
What would you guys recommend i do? which set up do you think would sound better? i have attached a a picture of my set up so you can have an idea of my space and what i am working with. Please, any advice is appreciated :)
Post edited by whitecamaross on
  • tommyt21
    tommyt21 Posts: 685
    edited January 2013
    Negative, run the second scenario people do it all the time everything will level out fine. i run a xpa 3 for my front 3 and let my pio take care of the other 4
    Living Room
    Fronts: RTi A7's
    Center: Csi A6 VR3 "Fortress Plus"
    Front Heights: Rti A1
    Surrounds: Rti A3
    Sub: HSU VTF-2 MK4 Damn this is a good SUB
    Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
    TV: Lg LW6500 55" Passive 3D
    Blu-Ray Panasonic BD 210
    XboX 360 Slim/Kinect
    Acoustimac red suede panels
  • rpf65
    rpf65 Posts: 2,127
    edited January 2013
    Agree. You shouldn't have a problem balancing the sound. Adding amps isn't necessarily for increasing volumn.
    edited January 2013
    Also agree, let the receiver handle the heights, those require the least amount of power.
  • whitecamaross
    edited January 2013
    That is what i was thinking. Do you think the lsi7s used as surrounds would make the sound much better over the fxia6s that are currently in place?
    edited January 2013
    No, the FX's will throw a wider soundfield than the 7's and give a more enveloping sound.
  • mufsoman
    mufsoman Posts: 640
    edited January 2013
    I have a RMB-1095 also with a 7.1 set up. The Rotel powers the front three speakers and one pair of side surrounds. I have a second pair of side surreounds and the back surrounds powered by the Pioneer SC07. Just make sure you recalibrate after installing the amp and tweak as necessary if you want to run the heighs a little hotter.
    Sony 83A80L TV and Roku Ultra
    Denon 3800
    Parasound HCA-2205A
    SVS Prime Pinnacle towers, Ultra center channel and Prime bookshelfs (side surrounds)
    Atmos: Polk OWM3 x 4
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
    Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
  • PSOVLSK
    PSOVLSK Posts: 5,412
    edited January 2013
    I found that to be true in my setup, especially with multi-channel music. I'm much happier with the 7's as my surrounds.
  • whitecamaross
    edited January 2013
    DSkip wrote: »
    Perhaps I'm mistaken, but shouldn't your FX's be switched (midwoofers facing towards listening position)?
    To my knowledge, that is how the fxia6 are meant to be positioned. I read the instructions and i also made sure the switch was set to the correct position.
  • whitecamaross
    edited January 2013
    PSOVLSK wrote: »
    what other speakers did you use as rears?
  • whitecamaross
    edited January 2013
    did you have to bump up the speaker level on the speakers that are being powered by your receiver? i was thinking that at some point the volume would be louder on your 5 speakers connected the amp?
  • mufsoman
    mufsoman Posts: 640
    edited January 2013
    I really didn't get an increase of volume from adding the amp as much as a cleaner/punchier/higher quality sound. I like to run my side and back surrounds a bit hotter than the Pioneer MCACC sets to, just because my preference to make them stand out more, so never paid attention to any volume difference between amped vs. unamped channels. Bottom line, I don't think the volume is that much different and if so, then just adjust your channel levels appropriately.
    Denon 3800
    Parasound HCA-2205A
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
  • PSOVLSK
    edited January 2013
    FxiA6 prior to the 7's.
  • Goldenboy72206
    Goldenboy72206 Posts: 126
    edited January 2013
  • Anthony Hinton
    Anthony Hinton Posts: 107
    edited January 2013
    Very nice, love the projector!
