Rotel RMB-1095 vs. B&K 200.5 vs. Parasound HCA-2205
falconcry72
falconcry72 Posts: 3,580
edited February 2013 in Electronics
Anybody have experience with these amps? I'm looking for a 5-channel amp for my LSiM's, and these three are on my short list. Prices seem comparable. Good reviews on all. Other suggestions? I know I like the Parasound HCA sound. I don't have any first hand experience with Rotel or B&K, but it would be nice to try something new, plus the HCA doesn't have balanced inputs. Thanks!
Post edited by falconcry72 on
  • falconcry72
    edited January 2013
    OK it's down to the B&K 200.5 vs. the Rotel RMB-1095. Thoughts?
  • rdb2001
    rdb2001 Posts: 791
    edited January 2013
    I have experience with both. I owned the B&K 200.5 and have heard the Rotel 1095. They are both great amps and you can't go wrong with either. I think the B&K is a little warmer sounding than the Rotel. That rotel series was the last of the good rotel amps in my opinon. What speakers are you driving with them?
  • rdb2001
    rdb2001 Posts: 791
    edited January 2013
    nevermind, saw you are driving LSIM's.
  • Emlyn
    Emlyn Posts: 4,735
    edited January 2013
    rdb2001 wrote: »
    Agree with all the above. B&K not only have a warmer sound, their big multichannel amps also tend to run physically hot. I had a 200.7 a few years ago until I switched to Parasound Halo. I found the Halo amps to be superior in every way, but they probably cost about 50 percent more than the Rotel or B&K in the used market for the same current output.
  • pearsall001
    pearsall001 Posts: 5,300
    edited January 2013
    Both are great amps & will serve you well. B&K's do tend to run on the hot side so proper ventalation is needed more so than the Rotel. Which ever one is the better deal might be a swaying factor here.
  • falconcry72
    edited January 2013
    Thanks for the responses, guys.
    Ventilation is not an issue. I'm not sure if the warmth of the B&K is a good thing or a bad thing. The LSiM's are pretty neutral, but I'd say they're on the warmer side already.
    I like the looks of the B&K better.
  • Emlyn
    Emlyn Posts: 4,735
    edited January 2013
    I still have a 200.2 that I use once in a while on my Focal/JMlabs speakers, which are known to be very revealing. It works great on those because they complement each other well. I did not like the B&K amp on LSi speakers very much. Too dark sounding for me. I understand the LSiM's are a bit different.
    tonyb Posts: 33,072
    edited January 2013
    Emlyn wrote: »
    That could have been contributed to the interconnects you used, B&K amps are just slightly on the warm side of nuetral and very musical. I would look at the B&k amp over the Rotel, but thats just my preference.
  • MADGSF
    MADGSF Posts: 603
    edited January 2013
    Not sure this helps as I only had the demo LSiM703 running off my B&K for all of two hours but I loved them while I had them.
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited January 2013
    I'm in the same boat as you with my lsim's. Was looking at these same three amps but since its for HT only I'm not wanting a warm sounding amp. Thinking about a class D amp.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited January 2013
    Put an Anthem mca5or 50 on that list as prices are comparable plus Anthem gives you a real sweet top end thats great for HT
  • mantis
    mantis Posts: 17,486
    edited January 2013
    Both are Awesome Amps , I might go with the B&K in this case.
    Dan
  • michael1947
    michael1947 Posts: 775
    edited January 2013
    My HCA 2200 has balanced inputs which I really like.
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
  • [Deleted User]
    [Deleted User] Posts: 1,394
    edited January 2013
    You know, it would have been really great if you were searching for an amp when you let go of your Usher's. ahem. I have the B&K 200.5 amp I would have used as layaway. Hahaha.
    Currently, actually used to run that amp with my LSIM 705s. At the time, I listened to the LSIM paired with unison research, jolida, yaqin and some other amp, all tubes... Later I tried my B&K, and it fell terribly short of the very good sound of tubes. I have not touched my B&K since.
    I feel the B&K does not work well with the polks. I would look for something not so warm sounding. But then again, I am an LSIM guy moving to Usher's and you, the reverse. Happy journey to you my man.
  • falconcry72
    edited January 2013
    leroyjr1 wrote: »
    Yea I was thinking the same thing. Based on other people's listening impressions, I think the B&K sound would be great with the LSiM's for music, but for HT I'd probably want somethin' a little sparklier (sp?).
    Let me know what you end up with!
  • falconcry72
    edited January 2013
    halenhoang wrote: »
    haha that's funny. Well, I didn't really move from Ushers to LSiM's in this system.. i moved from LSi's to LSiM's. In the 2-channel system, I moved from Ushers to my new 3.7's. :cool:
  • falconcry72
    Still on the hunt for a 5-channel amp in the 600-900 range. How would a sunfire cinema grand compare to the other models mentioned here??? I'm looking for something a little more forward sounding.
  • ViperZ
    ViperZ Posts: 2,046
    I have RMB-1075 (smaller brother to 1095) and definitely would not call it forward sounding. It's a very laid back and warm sounding (especially with my B&Ws).
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • bobsauto49
    bobsauto49 Posts: 973
    Forward sounding? Emotiva. Chit!! Did I just write that???????????:redface: Seriously though,I thought the Emo was a powerful amp,just to forward/bright sounding for me. But I was running them with a set of Rt2000i's,and then my KEF's. So if forward is what ur looking for? YMMV!
    "Everything I ever did in my life worthwhile I caught hell for"
  • falconcry72
    Anybody have thoughts on the Sunfire vs. Rotel vs. B&K???
  • deronb1
    deronb1 Posts: 5,021
    Not sure of the selection of Adcom 5 ch amps, but I would classify them as slightly forward of neurtral. Balsy, nonetheless.
