Wiring amp for mains only
Cuchulain
Cuchulain Posts: 66
If I use the pre out from my rx-v671 into an amp and from there to my mains, how does the avr know which siganls to send through the pre out for the surround sound? I'm thinking the mains get the full signal anyway. Or is the pre out assignable? I didn't see anything in the manual saying so. Would I wire some other way? Thanks in advance!--Brian
AVR: Integra DTR-50.4
TV: LG 50PS70
DVD/CD/BR: OPPO BDP 93
MAINS: Polk RTiA7
CENTER: Polk CSiA6
Heights: Polk VS 625RT (in wall)
SURROUNDS: Polk TC60i (in ceiling)
REARS: Polk R1
SUB: Polk PSW 125
Post edited by Cuchulain on
    txcoastal1 Posts: 13,505
    edited January 2013
    http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v671_black_u/
    The only preout I see in the specs is for a subwoofer
    tonyb Posts: 33,070
    edited January 2013
    In most cases, you need a full bank of 5.1 or 7.1 preouts, not just a subwoofer. Normally, if using just a 2 channel amp, you connect the front left and right preouts to the amps left and right inputs then connect speakers to the amp. No additional settings is required in the receiver. Unfortunately, it appears you don't have the preouts needed to do this.
  • Cuchulain
    Cuchulain Posts: 66
    edited January 2013
    What about the "line out" beside the zone 2 out?
    TV: LG 50PS70
    MAINS: Polk RTiA7
    CENTER: Polk CSiA6
    REARS: Polk R1
    SUB: Polk PSW 125
  • Cuchulain
    Cuchulain Posts: 66
    edited January 2013
    This amp I'm looking at: OSD AMP300. has "speaker in". Could this be used in the same way? Meaning does the amp take just the signal and amplify it and I would be relegated to using the volume on the amp for the mains?
    TV: LG 50PS70
    MAINS: Polk RTiA7
    CENTER: Polk CSiA6
    REARS: Polk R1
    SUB: Polk PSW 125
    tonyb Posts: 33,070
    edited January 2013
    Cuchulain wrote: »
    Technically you could do it that way, but it will only work for 2 channel sources. In other words, playing a 5.1 movie may not work using the line out as it's 2 different circuits. To use an amp, like we said, you need preouts, unless you just want to go 2 channel only for music and movies in that configuration.
  • Cuchulain
    Cuchulain Posts: 66
    edited January 2013
    Thanks for setting me straight, guys.
    TV: LG 50PS70
    MAINS: Polk RTiA7
    CENTER: Polk CSiA6
    REARS: Polk R1
    SUB: Polk PSW 125
