Piano Gloss Cherry RTiA5's
specd_out
specd_out Posts: 505
edited February 2014 in Speakers
I always loved Piano finished cherry wood or rose wood speakers. But 90% of them are out of my price range. For the longest time I have been considering doing a lacquer finish over the original cherry stain. I was googling how to do it when I cam across a guy who greatly improved his Lsi7 just by hand polishing them with some automotive polishing compounds. I used paint and detail cars so I had the same compound he used as well as a random orbit polisher and a high speed buffer.
So I took this guys idea and went one step further. I tested it by flipping over my center channel, hit with the high speed buffer and the polished it out with the random orbit. I did a 3 step process vs his 1 step. It came out great. So I did the rest of my setup.
Before
After
In the process of
Side by side comparison of the difference
No Photoshop I swear, thats just the finish
It took about 5hrs to do. I already had the tools and materials so it cost me nothing. If anyone is interested in doing it let me know I can offer some assistance
HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
ISF Level 2 Certified Calibrator
Post edited by specd_out on
«13
  • specd_out
    edited January 2013
    DSkip wrote: »
    Nice job! Makes the speaker look MUCH more high-end than it is.
    Hey now, what exactly are you saying here
    jk
    I said the same thing
  • teekay0007
    teekay0007 Posts: 2,289
    edited January 2013
    Nice work, spec, they look terrific! :biggrin: "The glare, can't handle the glare!" :cool:
    Any swirl marks on close inspection? What maintenance steps, if any, will it take to keep them looking like that? Are the tools and materials both readily available to anyone? How much skill is involved and can "mistakes" be readily corrected?
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2013
    WOW! that is absolutely beautiful, congratulations and great work!
  • mantis
    mantis Posts: 17,455
    edited January 2013
    Very nice , 3 step process I'm assuming you used. Cut polish and wax. Now keeping them like that should be pretty easy from here on out.
    Great job.
    Dan
  • WagnerRC
    WagnerRC Posts: 2,205
    edited January 2013
    Looks really nice.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited January 2013
  • GlennDog
    GlennDog Posts: 3,152
    edited January 2013
    WOW . . . really nice . . .
    I bet you're in marketing or photography now cuz the pics of the one speaker reflecting in the gloss of the other is just too kewl
    G
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • specd_out
    edited January 2013
    Yes I did wool with a light cutting polish on high speed buffer. Polishing compound on orbital with a light cut foam pad. Wax on orbital with a finishing pad.
    Teekay. No swirl marks. I wouldn't allow it lol. For a person not familiar with buffing I would not recommend using a high speed buffer. You can get a nice shine by hand or a better shine using a orbital polisher . if you go by hand or by orbital u can't really do any damage.
    F1nut Posts: 51,798
    edited January 2013
    Well, that would have been a complete waste because there is a clear coat finish over the cherry stain already. That finish has a flat sheen and to obtain a flat sheen flatting agents are added to standard gloss clear coats. The amount of flatting agents added determines the final sheen. The problem with a flat sheen is when it gets rubbed the sheen is no longer flat. Rub a flat sheen enough and it becomes a satin to semi-gloss sheen. I see this all the time and a lot with dining room tables where the areas that people have their arms on the table top become shinier than the rest of the table. I advise my customers that while I can apply a new flat sheen clear coat on top of the exsisting finish the same thing will occur. I advise them that they are better off having me rub out the flat sheen to a stain or semi-gloss or if they wish I can use polishing agents to get a gloss sheen, which is what you have done here. The downside to a gloss sheen is it shows dust like crazy and any scratches really stand out. Satin is the best choice of sheens, IMO.
    In this case there would be no need to cut or use rubbing compound as the finish is already smooth. Just proceed straight to using polishing agents. There would be no need to wax either. 99% of the time wax is a complete waste of time and money. As long as the clear coat finish is in good conditon it needs nothing applied to it.
  • mantis
    edited January 2013
    What about a cleaning Polish? What is some Oxidation has occurred over the years , maybe some sunlight hitting the one side of the speaker? I would think some kind of light compound or a polish with cleaners would help remove the sun staining?
    Waxing I thought would help protect the finish after it's been prepped and polished. In the automotive field , I use to detail cars and ran detail shops. I know Automotive paint is very different then finishes on wood but I would assume some of the technic's used to clean and protect the finish would be the same.
    I'm assuming your in the wood finishing or making business?
    Dan
  • specd_out
    edited January 2013
    Ok well that explains a lot. I had no idea that it was clear coated. I was in disbelief when I polished it up and it shined. I figured there was a protective lacquer that was dull. I have painted a few flat semi and gloss clears in the past. I never thought that it would be used on wood.
    The "cutting" polish I used was just a mequiers polish that uses the polymers that react with the heat from buffing to become abrasive. Its doesnt have any grit. Just slightly more aggressive then the polish. Wool pad definitely help speed up the process.
  • specd_out
    edited January 2013
    GlennDog wrote: »
    G
    I do neither, but I love doing photography for fun on the side. Sometimes I have an eye for a cool angle. Most of the time I dont lol
  • ratster
    ratster Posts: 324
    edited January 2013
    Very nice. Wish the black on my lsi15's looked like that.
    Main
    Parasound P5
    Parasound A21
    CA music streamer
    marantz 6005
    Clear Day dbl.shotgun
    Morrow Xlr
    1.7 Maggies
    Bedroom
    adcom Gfp750
    Adcom 555
    Rotel 1072
    CA tuner
    LsiM703
    Clear day dbl shotgun
  • htrdln
    htrdln Posts: 116
    edited January 2013
    that looks awesome!
  • zane77
    zane77 Posts: 1,696
    edited January 2013
    Great job, makes a really nice cabinet look awesome!
    Two Channel
    F1nut Posts: 51,798
    edited January 2013
    It's BIG business and completely unnecessary. Fine to use for cleaning if one must use something, but it does nothing to "help" a finish, nor can it moisturize the wood or any of the other stuff they say. All that is needed is a damp cloth to remove the dust....done.
    What i[f] some Oxidation has occurred over the years , maybe some sunlight hitting the one side of the speaker?
    You can't stop or fix oxidation, it will happen no matter what. You can apply a liquid polish that will help hide the issue until the polish evaporates. Since wax doesn't evaporate it will hide the issue longer. Neither wax or polish protect against oxidation, solvents, sunlight, heat or water. If sunlight has caused actual damage to the clear coat, it's time to restore the finish (depending on the finish) or refinish the item.
    Sunlight doesn't stain, it bleaches. Once the color is gone, it's gone. There are tricks to restore the color, but nothing you can buy off the shelf.
    Wax only protects in the sense that it reduces friction and therefore objects tend to slide rather than grab or dig in. Wax does nothing to "help" the finish.
    Same in the sense that the wax reduces friction and therefore objects tend to slide rather than grab or dig in. Wax does nothing to "help" the finish.
    I restore/conserve/refinish antique furniture as well as do work on newer furntiure. I am not a cabinetmaker.
    F1nut Posts: 51,798
    edited January 2013
    Roger that. I got in the habit of using 3M products, but know some others that use Meguiars.
  • specd_out
    edited January 2013
    I started with 3m but dare I say it, I felt that 3m didnt have some of the latest tech in polishes. I found I could get better finished product quicker and easier with Meguiars and I was able to use it on fresh paint. But thats in the automotive field.
    Heat activated abrasives are a god send when working on fresh paint
    I use 3m wet/dry sand paper
  • specd_out
    edited January 2013
    Took a few better shots with my accent lighting.
    the wood has so much vibrance to it now.
  • Bigerik
    Bigerik Posts: 149
    edited January 2013
    Holy crap. Those look amazing. Nice work.
  • Thorton
    Thorton Posts: 1,324
    edited January 2013
    Correct on both. Sheen comes down to personal preference. Just like house paint on walls for aesthetics and maintenance. I prefer satin but those speakers do look amazing. Nice job. Maybe I should change fields and start a business.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • Conradicles
    Conradicles Posts: 6,343
    edited January 2013
    Looking fantastic!
  • Thorton
    edited January 2013
    Correct again. The sunlight can do two things. One, break down the clear coat and cause it to bleach or other defects and two it can penetrate through the clear coat to the stain and cause discoloration.
    DAC: Bricasti M1SE
  • specd_out
    edited January 2013
    Thanks for all the compliments.
    I would gladly do this for anyone interested in having it done.
  • Elementtw1023
    Elementtw1023 Posts: 15
    edited May 2013
    specd_out wrote: »
    Yes please!! I wonder how the black would look all polished
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited May 2013
    F1nut ,you are so totally right about the sun bleaching. When I got my Bose 601s they were looked like so many pieces of driftwood both had been direct sunlight it seems for years then left in a hot attic to fry. I did resurrect them by a massive cleaning, staining w/ Olde English that just saoked right in then some beeswax polish after they set a while. Again I got them for $20 , $30 for the refoam kit kept them for about 9 months and flipped them on C/L for $215.
  • Poolgod69
    Poolgod69 Posts: 184
    edited May 2013
    Depressing.... I have the RTi A9's in black. I wanted the Cherry but could not find them for the price I got my A9's at (Fry's 419.00 each as a floor demo). I am willing to sell mine and purchase the cherries for a few bucks more.
    I think the speakers look insane and I like the spikes. What type are they and what are you placing them on?
    Marantz SR 5010
    Kenwood DR-V5070
    Polk RTi A9- Mains
    CSI A6- Center
    Elemental Designs A2-300 Subwoofer
    Panamax M4300-PM Power Conditioner
    Working on updating my set up :rolleyes:
  • amgala
    amgala Posts: 111
    edited May 2013
    Wow, just saw this thread now. The polished speakers look AMAZING! Great job
    Front Speakers: Polk Audio LSi15 x 2
    Center Speaker: Polk Audio LSiC
    Rear Speakers: Polk Audio LSiF/X x 2
    Subwoofers: Polk Audio PSW505 x 2
    AVR: Denon AVR-3313CI
    Amp: Emotiva XPA-5
  • WLDock
    WLDock Posts: 3,073
    edited May 2013
    Awesome!
    gudnoyez Posts: 8,166
    edited May 2013
    Those look great wish my black A5's gleemed like that.
