Harmony One Programming
brims
Sorry if this is in the wrong area.
Tomorrow my Yamaha RX-A3020 arrives. My RTi A9s, CSi A6, and DSW Pro 550wi wired and ready to plug in. I have to wire up my RTi A3s later. I'm using a Harmony One remote that I'm trying to get setup prior to the arrival of the centerpiece of my HT system and I'm having issues with how to set it up for watching TV. I'll be using an antenna connected directly to the TV. The TV has ARC as well as the 3020 so I'd just like to use my Polks for the audio. When I get to the screen that says "What input or channel does your Yamaha AV Receiver need to be on?" I don't have a clue what to select. I have a list of all the inputs that are available but since the audio will be sent to the receiver through ARC I'm stumped.
Post edited by brims on
For anyone with a Harmony remote and the A3020, you set the receiver to audio 1 if using ARC.
It took a while to figure everything out since I'm new to home theater systems, but it seems I've got it setup.
So far I'm liking the A9s, I listened to some music with them I don't find them to be bright, they are just right; I do think I will get an external amp to run them in the future. -
Not sure on the yamaha, but my onkyo receiver has a tv input that can either run back via the hdmi output (if supported by tv, mine doesn't) or use the optical from the tv back to the avr.
I just picked up a harmony 600 for $30, I love it!! I eventually want a harmony one, but at $150 cheaper, this does great.
