Faceplate or keystone jack needed for audio cable
dirtydenim86
Picked up an audio cable to use with my sub I am looking for a faceplate or keystone jack for it but I'm not sure which one to get will a regular RCA one do the trick?
Here is the cable I bought:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023603&p_id=2680&seq=1&format=2
looking to install a faceplate for a clean install just not sure which one to purchase help would be appreciated.
Would this keystone jack do the trick?
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10426&cs_id=1042601&p_id=6549&seq=1&format=2
Onkyo TX-NR809
RTI10 Polk Audio Front Tower Speakers
RTI4 Polk Audio Bookself
CSi5 Center Channel RTI Series
PSW505 12" Subwoofer
Post edited by dirtydenim86 on
Yes. Just place the insert into a standard keystone wallplate and you are done.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Serendipity wrote: »Yes. Just place the insert into a standard keystone wallplate and you are done.
Awesome Thanks!Onkyo TX-NR809
PSW505 12" Subwoofer -
I may have to run a 25ft audio cable to my sub I was wondering if there will be any signal loss using a cable of this length?Onkyo TX-NR809
dirtydenim86 wrote: »Picked up an audio cable to use with my sub I am looking for a faceplate or keystone jack for it but I'm not sure which one to get will a regular RCA one do the trick?
I am just about put in my order so I can move my sub to the back of the room but I just want to confirm that I will be able to run a 35ft coaxial audio cable with the yellow keystone faceplate above on both the sub end and the receiver end?Onkyo TX-NR809
I f you are running Audyssey or some other room correction it will compensate for any losses but I don't think yoy will have a problemHome Theater
Two Channel
