New Used Toy Philips 406
Irrenhaus
Irrenhaus Posts: 1,101
edited January 2013 in Electronics
Just got this home and works okay. Need to do some cleaning and tuning. Maybe check the belt as it starts a bit slow but then plays okay. Now the problem as always I may need a nice Phono-Pre or a nice Preamp with good phono stage.
Have this one on the local CL for $129.00 HAFLER DH-110
http://www.hifiengine.com/library/hafler/dh-110.shtml
And the rabbit hole keeps getting bigger and deeper......:smile:
HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
Post edited by Irrenhaus on
    mhardy6647 Posts: 35,005
    edited January 2013
    Unusual fully automatic suspended subchassis tt from the same model line as the venerable GA-212 (and, slightly later, GA-312). The 406 isn't terribly common IME.
  • Irrenhaus
    edited January 2013
    Well some cleaning has been done, the plate runs a bit slow so a new belt is in order and will be here this week. But was able to listen to some Miles Davis and so far it sounds good and the cartridge is good given that is the original Philips but will be looking for options. Also got a BBE phono preamp for now as the TT is a few feet from the AVR.
    So far happy with the TT.
    Cheers
    edited January 2013
    heh... I thought I had this blurb... :-)
  • Irrenhaus
    edited January 2013
    Nice thanks.
    I finally got it up and running new belt, good cleaning and new cartridge. After all settings were done correctly it sounds really good.
    Cheers.....
    edited January 2013
    Where'd you get your belt (if you don't mind my asking)?
  • Irrenhaus
    edited January 2013
    From here
    http://www.vintage-electronics.net/
