Sub Recommendation
Systems
Systems Posts: 14,872
edited June 2004 in Car Subwoofer Talk
What's up gentleman,
I am looking for a subwoofer recommendations. Here is my setup.
95 Celica Hatchback
Hifonics Zues ZX4400
Front Speakers Polk db6750
Rear Speakers Polk db675
Alpine 9827 Deck
The Fronts are hooked up to the amp, and the rears are being run off the deck.
I'm going to bridge the other two channels for the sub.
It would output 170 watts at 4ohms according to the manual.
I am pretty happy with the amp, although I probably should have gotten, the ZX6400.
I listen to mostly rock, and i'm looking for a clean tight hit. If I could find a nice 8" that would fit the bill, that would be cool, but a 10" would be okay too. I'm not looking to shake the ground, just round out my system.
What do you guys think?
Testing
Testing
Testing
  • TrappedUnder Ice
    TrappedUnder Ice Posts: 975
    edited May 2004
    I'll get flamed for this...but with that power....I'd run a Pair of JL 8w0's. They will be tight..box will be about .8cubes and will do that job off that amp. Dont take much to get them loud
    And if folks say the 8w0's wont go low enough..I will argue that. I have one set for center..but was playin with it quite a bit... does the job well...
    other options
    IdQ10/ID8
    RE10
  • Systems
    edited June 2004
    I'd go with a single 12w0 over two 8's.
    or maybe a EDkx from audiohole, if theres any left.
    Testing
    Testing
    Testing
