TV Viewing distance
Mike Kozak
Mike Kozak Posts: 931
edited January 2013 in The Clubhouse
How far do you sit from your big screen TV? I looked it up and I am supposed to be 6.5 ft from my 50" Panny. Seems a bit close but I tried it last nigt anyway............
Post edited by Mike Kozak on
  • Willow
    Willow Posts: 11,229
    edited January 2013
    About 12 ft from my 42".
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited January 2013
    9ft from a 60"
  • decal
    decal Posts: 3,205
    edited January 2013
    I would think you could figure this out for yourself!!!!! smiley_rotflmao.gif
  • Tbone289
    Tbone289 Posts: 661
    edited January 2013
    I'm about 12 ft. from my 52".
    For me, distance to the front speaker channels is more important than distance from the LCD monitor. So, I would be more likely to decide the ideal distance for audio, then buy the appropriate-sized TV rather than buy a TV and then figure out the appropriate distance.
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
  • drselect
    drselect Posts: 664
    edited January 2013
    And did you like it?
    I was about 12 ft from my 55" panny and moved to about 9 ft. This helped with my speaker placement. The result was better sound and better tv viewing.
  • Tbone289
    Tbone289 Posts: 661
    edited January 2013
    drselect wrote: »
    Yes. But speaker placement distance relates a great deal to the size and shape of a room and how the listener is seated, so I can't really relate my experience with yours.
  • drselect
    drselect Posts: 664
    edited January 2013
    Tbone289 wrote: »
    Sorry should have been a little clearer. I agree with your statement. For me it was a win-win. I wanted better speaker placement which could only occur by moving closer to tv. This resulted in better viewing and better sound. I was concerned about moving closer to the tv but it worked out for my situation. That was also why I was asking the OP if he liked it when he moved closer.
  • Tbone289
    Tbone289 Posts: 661
    edited January 2013
    Of course, that makes sense. Honestly, I wish my room would allow me to sit closer. 12' is a little further than I'd like with a 52".
  • George Grand
    George Grand Posts: 12,258
    edited January 2013
    My best viewing distance with a 50" seems to be about 8-9 feet. My best listening distance with a 50" is with my nose up against the screen.
  • tophatjohnny
    tophatjohnny Posts: 4,188
    edited January 2013
    9' from my 55" and 17' from the 32" in the bedroom???????
  • steveinaz
    steveinaz Posts: 19,545
    edited January 2013
    I'm 11ft from my 58" plasma.
  • hochpt21
    hochpt21 Posts: 5,423
    edited January 2013
    9 from a 50. Feels just right. We were at 8 from a 32 for the last 3 years...so yea...this feels better.
  • PubFiction
    PubFiction Posts: 105
    edited January 2013
    http://www.hdtvtest.co.uk/Article/How-Far-Should-I-Sit.php
    That said the vast majority of people do not have much choice because our rooms have limits for practical purposes, I think I would need a 65 inch TV for my room but the 55inch already cannot be centered because it too large. And most homes I go into are sitting 10+ feet from a 42 inch.
  • 11tsteve
    11tsteve Posts: 1,166
    edited January 2013
    9 ft from my 40"... about the same from my 37" in the bedroom. feels good....
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
    treitz3 Posts: 19,968
    edited January 2013
    We sit between 12 to 14' feet away from our 46" TV. I have always preferred sitting even further away as the picture just looks more cohesive. We returned the 50" TV because the flaws and/or artifacts were too easily spotted. Keep in mind, we're not anywhere close to what some refer to as a "videophile". We sit further away from that on a 32" in the bedroom but with HD, there is no issue even though with that setup I would prefer to be closer.
  • pearsall001
    pearsall001 Posts: 5,257
    edited January 2013
  • seabeerob213
    seabeerob213 Posts: 1,843
    edited January 2013
    8-9 feet from my 40
  • Tornado Red
    Tornado Red Posts: 939
    edited January 2013
    I'm 2743mm from my 1524mm Panny.
  • badchad
    badchad Posts: 348
    edited January 2013
    I think this illustrate how wide opinions vary on "viewing distance". I'm about 12 ft from 70". It seems most "recommendations" are between 1-2X the size of the screen. Personally, I think the THX recommendation of 7.8 ft would be a bit close for me.
    Polk Fronts: RTi A7's
    Polk Center: CSi A6
    Polk Surrounds: FXi A6's
    Polk Rear Surround: RTi4
    Sub: HSU VTF-3 (MK1)
    AVR: Yamaha RX-A2010
    B&K Reference 200.7
    TV: Sharp LC-70LE847U
    Oppo BDP-103
  • wayne3burk
    wayne3burk Posts: 939
    edited January 2013
    i'm about 12 feet from a 60" screen - and it seem satisfactory to me - I'm sure the THX recommendations must have something to do with the how much the screen fills your field of vision.
    Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie
    edited January 2013
    badchad wrote: »
    No doubt.
  • Tornado Red
    edited January 2013
    I remember when I got the 60" last year, I was setting it up thinking "this thing is just stupid big". About 2 weeks later I'm thinking "yeah, I could have gone for the 70". Which brings me to what the tv salesman told me "after you buy a big tv, everyday the screen gets smaller."
  • drselect
    drselect Posts: 664
    edited January 2013
    I think the reason we don't like sitting close to the tv is because of that voice in are head we remember screaming at us... "Get back from the TV you are to close".
    I would guess that sitting 10 ft from a 50" screen is like siting 50yrds from a 40ft screen. But than again my math not be right because I come up with 54 for the answer in that other thread not 7.
