Its time for a Polk speaker upgrade. I have a few questions....
  • Lietuvis91
    Lietuvis91 Posts: 909
    edited January 2013
    Based on those pictures, I was thinking rtia5 towers and a csia6 center. Will easily run on his current avr, and should be an improvement in sound quality over the r50s.
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
  • deronb1
    deronb1 Posts: 5,021
    edited January 2013
    tonyb wrote: »
    Nice build, for austhetics but not so much for sound. Since your dead set on keeping it, forget floorstanders and look for a bookshelf speaker that ports out of the front, not the back, put it on a stand in that cubby hole on the sides. Speakers throw sound in many directions, not just forward, and that cubby hole limits those dispersions of sound.
    +1....If the drivers don't stick out futher than the middle of the cabinet (where the tv is) then you will get little to no imaging or reflective sound. For HT, may not be too big of a deal, but for dedicated music? Not an ideal placement.
    F1nut Posts: 52,373
    edited January 2013
    Remove the cubby holes, add a panel to cover the now open sides and you'll be able to properly position whatever speakers you end up with because it doesn't matter what speakers you put in the cubby holes, they will never sound right.
  • BOTTLEDZ28
    BOTTLEDZ28 Posts: 25
    edited January 2013
    Thanks for the advice but I cannot remove the side pieces from this thing. It just aint happening so I will just have to except the sound that comes from any speaker that I place in them locations until the day comes when I decide to start over with a whole new setup. If I didnt just install a brand new carpet in that room on Chistmas Eve then I would have removed the sides but now I would be left with two square bare patches on the floor unless I got clever and designed some type of raised pad for the floor speakers to stand on. I would still have a lot of work ahead of me though since the drywall would need to be done as well as new side panels on what is left and then repaint the whole wall once again.
    Besides, my wife is in love with the entertainment center. She says it matches the fireplace surround and gives the room a warm cozy feeling unlike some of the metal and glass stands on the market. I originally made this thing when I had a Sony rear projection which was about 18" deep. Sony gave me a new LED TV last year and I ALMOST tore that thing down to mount the TV on the wall but my wife talked me out of it claiming that it would be a shame to destroy something I spent so much time and effort on to make.
    On a side note. I would sure hate to do that project and then sit back on the couch and say " the audio sounds the same!"
    So, with that being said, I may decide to either experiment with a 2 or 3 channel amp and see where that takes me or look for a deal on some Monitor 60s and just toss them in there with the face of them flush with the custom speaker grills I have already made. No, I am not running the OEM grills. Just the black cusrtom made grills to see in the pic.
    txcoastal1 Posts: 13,520
    edited January 2013
    http://www.artisonusa.com/loudspeakers/lcr-dm-series/
    Maybe this type of speaker would suit your placement better
    F1nut Posts: 52,373
    edited January 2013
    BOTTLEDZ28 wrote: »
    Sometimes you have to punt. :cool:
    Like I said before, just pull them out into the room and with the proper toe-in give them a listen. Then you'll know.
  • cowtrimmer
    cowtrimmer Posts: 201
    edited January 2013
    Try putting egg crate or pyramid foam inside those enclosures and it might dampen some of the resonance.
  • drumminman
    drumminman Posts: 3,396
    edited January 2013
    One other option you can try is to build a new "floor" in the cubbies that extends several inches out from the front. How far is up to you. You could then dampen the inside of the cubby as cowtrimmer suggested, and get the speakers out far enough that the front baffle would be in front of the TV between the speakers.
    Wouldn't solve all the problems, but should improve imaging and overall sound.
  • michael1947
    michael1947 Posts: 775
    edited January 2013
    I hate to burst your bubble but I feel you should start from scratch. Remove the wonderful home built cabinet to the basement or somewhere you can get some future use. Replace the missing base board molding along the back wall, spruce up the room with a new paint job and be ready for a significant up-grade. It really won't cost too much as you seem to be handy. Look at some of the "system showcases" here on the forum and start making a plan. Those nice modern looking glass tables that hold your tv and house your electronics in "open air" will look sharp and get your electronics out from their little cubbys. In the end you will have far superior enjoyment from your AV system.
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
  • math wizard
    math wizard Posts: 106
    edited January 2013
    BOTTLEDZ28 wrote: »
    Well it looks like its time to upgrade my 5.1 HT setup in the family room (15'x19'). I am currently running a pair of Polk R50s , CS2 ( I just upgraded that from a CSi30 today.) I am running R15s for rears and a PSW505 sub. My AVR is an Onkyo TX SR706. I would like to upgrade the R50s to possibly the Monitor 60s or 70s. Main use of them will be regular TV watching mainly with the occasional Bluray movie or two on the weekend. I also love to listen to music. I am slowly learning this 2 CH stereo mode but I just don't care for the sub being out of the equation. Maybe new speakers will fix that.
    Anyway, Im looking for advice on whether or not I should step up to the 70s ($370 shipped from Polks ebay store) or the 60s for $279 shipped. Is the extra $90 worth it or will I be wasting money considering I will have these speakers crossed over at 80hz? I don't want to waste my money but I also don't want to always wonder what I am missing, if any by just getting the 60s. I am new to this hobby so any advice will help me a lot. Thanks.
    Rti's with a good amp. RTi's can be found used for very little
    Processor - Emotiva UMC-200
    Pre-Amp (2 Ch) - Emotiva USP-1
    DSP Minidsp nanoAVR DL
    DAC (2 Ch) - Emotiva XDA-2
    Amp (Fronts) - Emotiva XPA-2
    Amp (Center/Surrounds) - Emotiva XPA-3
    CD - Emotiva ERC-1
    Fronts - Polk Audio RTi 12
    Center - Polk Audio CSi5
    Rears - Polk Audio RTiA1
    Sub - Epik Knight
    Sub EQ - Velodyne SMS-1
    Monitor - Sony XBR65X850C
    Blu-Ray - OPPO BDP-203
    Network Media Player - Chromecast Ultra
    Power Conditioner - APC H15
    Power Conditioner - Emotiva CMX-2
    PVR - DirecTV C61k
    Remote - Harmony Touch w/Hub
  • Pastorfuzz
    Pastorfuzz Posts: 24
    edited January 2013
    You can pick up a nice used Sunfire amp 200x5@ 8 ohm now days for $800 to $1000 bucks.
    I got one for $950 and took it to the shop for inspection and upgades. 2 leaking capacitors replaced and unit adjustments for $185.
    It made a BIG difference to the way my speakers sounded.(4 monitor 70's and CS2) Receiver is a Marantz SR8500.
    Also check your speaker crossovers. I've had speakers start to sound weak before and the crossovers were the culprit!
