just curious
seabeerob213
seabeerob213 Posts: 1,843
any harm in setting my avr atop my sub?
Post edited by seabeerob213 on
  • decal
    decal Posts: 3,205
    edited January 2013
    Harm, I highly doubt it. Sound quality might suffer. Just MHO.
  • seabeerob213
    edited January 2013
    ok thanks :)
  • michael1947
    michael1947 Posts: 775
    edited January 2013
    Yes, potentially all of the shaking of the sub could loosen connections within the ARV. If you can find or build a small table with 4 legs to fit over the sub you could then place the AVR just above the sub. Report back with your new set-up and PHOTOS...we like pictures:razz:
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
  • seabeerob213
    edited January 2013
    pics in a bit, this is still a work in progress, if i get some speaker stands this will change a lot
  • seabeerob213
    edited January 2013
    still gotta refine it but this is what i have decided to do for now
  • seabeerob213
    edited January 2013
    the tv is on top of a HTIB "sub"woofer to see it over the csi3, and that is a usb powered fan on top of the AVR to help airflow in that tight area
  • Speedskater
    Speedskater Posts: 495
    edited January 2013
    Judging by the size of the speaker system, I don't think that we will see (or hear) any 115dB SPL train wreck movies with this system.
    But for big & loud sub-woofers, putting any component with a hard-drive on it is definitely a bad idea. And probably a bad idea for other components.
  • pollac
    pollac Posts: 2
    edited January 2013
    Refer the specific path and made on the useful things for the good path.....
  • seabeerob213
    edited January 2013
    didnt put it there, made it work, for now, i dont think i like it though
