Re-cone or replace?
KellyMic
KellyMic Posts: 166
edited January 2013 in Speakers
I'm looking at getting a couple speakers fixed with blown woofers. Curious what user feedback is on just having them re-coned instead.
Polk Studio Monitor 4.6 Series 2's, Polk RT1000p's, Polk LSi25's, Boston Acoustic VR-975's
Crown D-75, Crown CE1000, Crown CE2000
Post edited by KellyMic on
    F1nut Posts: 51,731
    edited January 2013
    Which speakers?
  • KellyMic
    KellyMic Posts: 166
    edited January 2013
    The speakers are Boston Acoustics VR-970. These both have a 10" and 12" side firing woofers. The 12" rattles terribly in both. Upon inspection they were visibly separated on the outer ring. I glued them back up and they sounded great for like a week but they then came apart in another section. They are needing to be replaced properly. I've seen re-coning is from $40-$60 each and that doesn't include shipping back and forth. At that point I'm getting close to $150 to $175. Curious if it's better to just put in new ones at that point.
    F1nut Posts: 51,731
    edited January 2013
    Only you can decide if it is worth the money or not. The current value may help with that decision.
