bi-amp with xlr (balanced) inputs
Sparky
I am currently using RCA interconnects between my pre-amp and amp but want to switch to xlr (balanced). I am running a 5.1 system and using the 2 extra channels on the amp to bi-amp my mains (RTi150).
My question is... what is the best way to do this? The only way I know of would be to split the two front outputs from the pre-amp. I haven't seen any Y xlr cables. Do they make them? Anyone know where to get them? Any reason why I shouldn't split the xlr cables?
Thanks for the help,
Sparky
Sparky
Mains: Polk RTi150 (bi-amped 200 x 2)
Center: Polk CSi40
Surrounds: Polk TC80i
Rear: Polk RTi38
Subs: (2) SVS 20-39 CS+
PrePro: B&K Ref 50
Amp1: Sherbourn 7/2100A (200 wpc x 7)
Amp2: Sherbourn 7/1250A (125 wpc x 7)
SubAmp: Denon POA2800 (350 wpc x 2)
DVD: Denon DVM-2815
DVR: Dish Network PVR508
Sat: Dish Network 301
Panamax Max 5300
Panamax Max 2-20
Center: Polk CSi40
Rear: Polk RTi38
PrePro: B&K Ref 50
DVD: Denon DVM-2815
Panamax Max 5300
Panamax Max 2-20
Post edited by Sparky on
Guitar Center carries them. From a previous response on the same subject, the person I informaed of this was not able to fond them online. They are available in the store, bought them myself, but you might have to hit a couple of locations. One store I went to had only M to F, whereas the second store only had F to M.
Thanks wlrandall,
I'm afraid that won't work for me since the closest Guitar Center is over 300 miles away. I would need to buy something online.
SparkyMains: Polk RTi150 (bi-amped 200 x 2)
Center: Polk CSi40
Rear: Polk RTi38
PrePro: B&K Ref 50
DVD: Denon DVM-2815
Panamax Max 5300
Panamax Max 2-20 -
There are several places that you can get them such as ...
http://www.bhphotovideo.com/bnh/controller/home?O=NavBar&A=search&Q=&ci=4173
and other more capable devices such as ...
http://www.whirlwindusa.com/split.html
Do your own searches for XLR + Y + Cable or XLR + Splitter -
You can find them at www.mitcables.comPolitical Correctness'.........defined
