New to This..
Kenoskater
Kenoskater Posts: 7
I have the Polk Audio Monitor60 Series II i just got two of them with my Yamaha RX-V371BL 5.1-Channel A/V Receiver. So i connected my speakers with RCA AH16100SN 100 Ft. 16-Gauge Speaker Wire and it just sounds terrible. It sounds flat and staticy. Do i need a higher cable then 16 gauge? I can record and upload if that helps. :sad:
Post edited by Kenoskater on
  • BlueFox
    BlueFox Posts: 15,250
    edited December 2012
    Hopefully, you didn't use 50 feet for either side. The easiest way to answer your question is to go to the hardware store and buy 'x' feet of 12 gauge, twisted, stranded, low voltage copper wire. Just use enough wire to connect the speaker to the amp. If it sounds the same then wire is not the problem, and you are only out a few dollars.
    If it sounds better then you are in trouble. :smile:
  • Kenoskater
    Kenoskater Posts: 7
    BlueFox wrote: »
    Well i just found out it was the conductor. It wasn't tight enough so it was only playing half the speaker. Thanks for the help thorough, new to this stuff :eek:
  • BlueFox
    Great. Starting the new year with new gear. Have a good year, and enjoy.
  • Speedskater
    Speedskater Posts: 495
    edited January 2013
    I think that the "RCA" brand cable sold in some big box stores is aluminum wire! (and it may be undersized, as well). This is not the old well respected RCA that was the leader in electronics for decades.
  • michael1947
    michael1947 Posts: 775
    edited January 2013
    If they use up all the aluminum for krappy speaker cables then what will be make beer cans out of:loneranger:
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
  • Speedskater
    edited January 2013
  • seabeerob213
    seabeerob213 Posts: 1,843
    edited January 2013
    i believ the rca cable i have is aluminum, sadly, the 14 AWG stranded copper stuff i have isnt enough, so i have my center and right surround on copper and surround left on the rca, as surrounds i dont hear much difference, but the volume is a bit lower on the rca cable, i noticed it was aluminum when i set up my new avr, i pulled it out of the spring clip on the old one and it came out silver in color
  • astar13656
    astar13656 Posts: 164
    edited January 2013
    Maybe the wire is recycled beer cans....
  • Phil17108
    Phil17108 Posts: 2
    edited January 2013
    I like the idea of the low voltage outer lighting wire as in malibu. have used it for years and have never found it green bet it's 99.99 % oxygen free but not much less then monoprice.
  • qenssal
    qenssal Posts: 1
    edited January 2013
    Great post and interesting comments! Looks like people have a strong opinion about both sides of the coin!
  • goofyGAguy
    goofyGAguy Posts: 545
    edited January 2013
    qenssal wrote: »
    You forgot the link to your spam.
    My humble setup...
    ...is no more. :cry:
  • decal
    decal Posts: 3,205
    edited January 2013
    goofyGAguy wrote: »
    He's trying to get his foot in the door first!!!!!
  • hochpt21
    hochpt21 Posts: 5,423
    edited January 2013
    goofyGAguy wrote: »
    Which is super innoying, because today is the one day I wanted to click on some.
  • Mikey081057
    Mikey081057 Posts: 7,127
    edited January 2013
    You can get a 100 foot roll of decent copper cable for about $50 on ebay or amazon 12 ga. would be best.
    Garage | Polk Monitor 5B's
  • oleon621
    oleon621 Posts: 178
    edited January 2013
    You can always go the blue jeans cable route. Affordable and well built.
    Front- RTI A7,(powered by ADCOM GFA 5500)
    Center- CSI5,
    Surrounds- RTI 6 and Rear Surrounds- TS 15.
    TV-Panasonic P55ST50
    SUB-SVS PB10-NSD and PSW505
    Receiver- Yamaha Aventage RX-A2000
