Newb Question
valkyrie00
valkyrie00 Posts: 33
I will be connecting an Emotiva XPA 5 amp to a Denon 3313 Ci receiver. I will be powering all channels except the 2 rear speakers in a 7.1 setup through the Emotiva. The Denon will drive the two rear speakers. My question is: Is there only one RCA cable for each speaker from the receiver to the amp? I now this is rudimentary for all of you but I'm trying to get this right before the equipment arrives and I am a complete newb at this. Thanks for the help!
Also is there only one end on the cable for the amp and the receiver? Can you recommend some good RCA cable...?
Polk Audio RtiA9 - Front x 2
Polk Audio CsiA6 - Center
Polk Audio FXiA6 - Surrounds x 4
Denon AVR 3313 CI
Oppo BDP 103
Emotiva XPA-5
SVS PB12 NSD
Post edited by valkyrie00 on
  • brgman
    brgman Posts: 2,859
    edited December 2012
    Each channel will only need one RCA cable from teh Denon to the Emo.
    As far as "good"RCA cables it depends on budget and desire.
    You want to pay $10 each? $100 each? $1,000 each?
    I’M OFFENDED!!!!
  • decal
    decal Posts: 3,205
    Add another 0 and get a decent cable !!!!
  • valkyrie00
    Thanks brgman. I guess I want the most for my money. Not spending $1,000. I've read some who swear by the most expensive cabling and some who swear it doesn't matter as long as it meets industry standards. As stated, I am a complete newb but it seems logical to me that as long as RCA cables have been out they should have about the same performance. As long as they're in good condition etc. I am a complete newb though... Someone suggested Blue Jeans cable...
    Denon AVR 3313 CI
    Oppo BDP 103
    Emotiva XPA-5
    SVS PB12 NSD
  • brgman
    brgman Posts: 2,859
    I have heard good things about BJ and i'm sure some will pipe in about others.
    Pepster on here makes nice cables for a great price if you want bang for the buck simple.
    I’M OFFENDED!!!!
  • cfrizz
    cfrizz Posts: 13,415
  • soundfreak1
    soundfreak1 Posts: 3,414
    Dont know about the highemd cables but have learned that you cant beat a BJ.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • deronb1
    deronb1 Posts: 5,021
    Lol...unjacketed are the best!
  • BlueFox
    BlueFox Posts: 15,251
    For your needs, the inexpensive cables are fine. The more expensive cables are for after you develop an ear for nuances, and want to try and extract every bit of music from the source. Some people never develop the ability to hear nuances so they try and convince others those nuances do not exist. Pay no attention to those people behind the curtain. Before getting better cable you will be upgrading your gear first. Then you can start to worry about cables, power cords, vibration elimination, etc.
  • math wizard
    math wizard Posts: 106
    edited January 2013
    valkyrie00 wrote: »
    I use Emotiva X-series cables and they are great. These are on sale until 01/15/13. Hurry.
    http://shop.emotiva.com/collections/interconnects/products/xvrca
    Processor - Emotiva UMC-200
    Pre-Amp (2 Ch) - Emotiva USP-1
    DSP Minidsp nanoAVR DL
    DAC (2 Ch) - Emotiva XDA-2
    Amp (Fronts) - Emotiva XPA-2
    Amp (Center/Surrounds) - Emotiva XPA-3
    CD - Emotiva ERC-1
    Fronts - Polk Audio RTi 12
    Center - Polk Audio CSi5
    Rears - Polk Audio RTiA1
    Sub - Epik Knight
    Sub EQ - Velodyne SMS-1
    Monitor - Sony XBR65X850C
    Blu-Ray - OPPO BDP-203
    Network Media Player - Chromecast Ultra
    Power Conditioner - APC H15
    Power Conditioner - Emotiva CMX-2
    PVR - DirecTV C61k
    Remote - Harmony Touch w/Hub
  • John K.
    John K. Posts: 822
    edited January 2013
    Valkyrie, a coaxial cable with an RCA plug on each end is used. For several years I've used these cables in various lengths. They do this very simple job as well as it can be done and there's no good reason to pay more.
    F1nut Posts: 51,787
    edited January 2013
    Wrong!!!
  • kevhed72
    kevhed72 Posts: 5,146
    edited January 2013
    Spend a little more money and buy something like Signal Cable Analog 1 or 2's, or Audioquest Sidewinders.
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited January 2013
    +1 Bluejeans cable.
